Hello:
I am currently deploying a LoRa Server based network and one of my main goals is to install several gateways from different vendors in orden to test the hardware compatibility with LoRa Server software.
I know (via user manual) that LoRa Server supports four gateway vendors, that is: Kerlink, Laird, MatchX and Multitech (https://docs.loraserver.io/lora-gateway-bridge/install/gateway/), therefore I would like to know if is possible to use another vendors out of that list and what features would have to support other non-listed gateways in order to work out properly in a LoRa Server environment.
For example, I have found following devices.
- https://lorixone.io/#products
- https://www.kerlink.com/product/wirnet-station/
- https://matchx.io/shop/lpwan-gateway
- http://www.dragino.com/products/lora/item/117-lg01-p.htm
Then, could I include these devices in my LoRa Server net ?.
Thank you very much in advance.
best regard.
Every gateway on which the packet-forwarder (https://github.com/lora-net/packet_forwarder) can be / is installed should work with LoRa Gateway Bridge, and thus LoRa Server
