Hi all!
Sorry for disturb. I’m newbie with chirpstack and i want to install it on ubuntu 20.04LTS. In the tutorial ubuntu 20.04 wasn’t mentioned… Someone have installed it successfully and run it in production without problem?
Thanks a lot.
…keep going…
I’m running it in PROD, UAT and TEST without any problem.
Regards.
I just set up the application and network servers on Ubuntu 20.04. If you follow the instructions you shouldn’t have a problem. You should be able to install everything with apt.
