I am Not sure what am I doing wrong.
I am using Arduino Nano with the Sx1276 Lora chip and Rak7244 Gateway. ChirpStack Gateway-bridge, Network Server and App server are installed on a Ubuntu server.
Do I need to check Gateway, Node or OTAA Keys?
Yes, you’re need to check packet forwarder, why it not send the join accept to your endnode. also check the endnode regional frequency settings.
I am Using Arduino LMIC Library. Uplink and Downlink are both 915mhz frequencies, so I think i am on right frequencies. But i’ll check the packet forwarder and post the update. Thanks
log about nothing.
I ask You to check the packet forwarder, not bridge
no. this is tcpdump
which packet forwarder you’re using? learn the docs regarding packet forwarder and inspect the pf log output
P.S. please, do not use the screenshots, they are not readable, just cut and paste the plain text.
I am using Semtech Packet Forwarder. Following is its log file
/var/log $ tail -f syslog
Mar 22 22:30:12 rak-gateway ttn-gateway[23786]: # TX rejected (too early): 0.00% (req:1, rej:0)
Mar 22 22:30:12 rak-gateway ttn-gateway[23786]: # BEACON queued: 0
Mar 22 22:30:12 rak-gateway ttn-gateway[23786]: # BEACON sent so far: 0
Mar 22 22:30:12 rak-gateway ttn-gateway[23786]: # BEACON rejected: 0
Mar 22 22:30:12 rak-gateway ttn-gateway[23786]: ### [JIT] ###
Mar 22 22:30:12 rak-gateway ttn-gateway[23786]: # SX1301 time (PPS): 1922770806
Mar 22 22:30:12 rak-gateway ttn-gateway[23786]: src/jitqueue.c:448:jit_print_queue(): INFO: [jit] queue is empty
Mar 22 22:30:12 rak-gateway ttn-gateway[23786]: ### [GPS] ###
Mar 22 22:30:12 rak-gateway ttn-gateway[23786]: # Valid time reference (age: 0 sec)
Mar 22 22:30:12 rak-gateway ttn-gateway[23786]: # GPS coordinates: latitude 50.67613, longitude -120.35428, altitude 444 m
Mar 22 22:31:42 rak-gateway ttn-gateway[23786]: ##### END #####
Mar 22 22:31:42 rak-gateway ttn-gateway[23786]: JSON up: {“stat”:{“time”:“2020-03-22 22:30:12 GMT”,“lati”:50.67613,“long”:-120.35428,“alti”:444,“rxnb”:0,“rxok”:0,“rxfw”:0,“ackr”:100.0,“dwnb”:0,“txnb”:0}}
Mar 22 22:31:42 rak-gateway ttn-gateway[23786]: INFO: [up] PUSH_ACK received in 0 ms
Mar 22 22:31:42 rak-gateway ttn-gateway[23786]: INFO: [down] PULL_ACK received in 0 ms
Mar 22 22:31:42 rak-gateway ttn-gateway[23786]: ##### 2020-03-22 22:30:42 GMT #####
Mar 22 22:31:42 rak-gateway ttn-gateway[23786]: ### [UPSTREAM] ###
Mar 22 22:31:42 rak-gateway ttn-gateway[23786]: # RF packets received by concentrator: 0
Mar 22 22:31:42 rak-gateway ttn-gateway[23786]: # CRC_OK: 0.00%, CRC_FAIL: 0.00%, NO_CRC: 0.00%
Mar 22 22:31:42 rak-gateway ttn-gateway[23786]: # RF packets forwarded: 0 (0 bytes)
Mar 22 22:31:42 rak-gateway ttn-gateway[23786]: # PUSH_DATA datagrams sent: 1 (158 bytes)
Mar 22 22:31:42 rak-gateway ttn-gateway[23786]: # PUSH_DATA acknowledged: 100.00%
Mar 22 22:31:42 rak-gateway ttn-gateway[23786]: ### [DOWNSTREAM] ###
Mar 22 22:31:42 rak-gateway ttn-gateway[23786]: # PULL_DATA sent: 3 (100.00% acknowledged)
Mar 22 22:31:42 rak-gateway ttn-gateway[23786]: # PULL_RESP(onse) datagrams received: 0 (0 bytes)
Mar 22 22:31:42 rak-gateway ttn-gateway[23786]: # RF packets sent to concentrator: 0 (0 bytes)
Mar 22 22:31:42 rak-gateway ttn-gateway[23786]: # TX errors: 0
Mar 22 22:31:42 rak-gateway ttn-gateway[23786]: # TX rejected (collision packet): 0.00% (req:1, rej:0)
Mar 22 22:31:42 rak-gateway ttn-gateway[23786]: # TX rejected (collision beacon): 0.00% (req:1, rej:0)
Mar 22 22:31:42 rak-gateway ttn-gateway[23786]: # TX rejected (too late): 0.00% (req:1, rej:0)
Mar 22 22:31:42 rak-gateway ttn-gateway[23786]: # TX rejected (too early): 0.00% (req:1, rej:0)
Mar 22 22:31:42 rak-gateway ttn-gateway[23786]: # BEACON queued: 0
Mar 22 22:31:42 rak-gateway ttn-gateway[23786]: # BEACON sent so far: 0
Mar 22 22:31:42 rak-gateway ttn-gateway[23786]: # BEACON rejected: 0
Mar 22 22:31:42 rak-gateway ttn-gateway[23786]: ### [JIT] ###
Mar 22 22:31:42 rak-gateway ttn-gateway[23786]: # SX1301 time (PPS): 1952249814
Mar 22 22:31:42 rak-gateway ttn-gateway[23786]: src/jitqueue.c:448:jit_print_queue(): INFO: [jit] queue is empty
Mar 22 22:31:42 rak-gateway ttn-gateway[23786]: ### [GPS] ###
Mar 22 22:31:42 rak-gateway ttn-gateway[23786]: # Valid time reference (age: 0 sec)
Mar 22 22:31:42 rak-gateway ttn-gateway[23786]: # GPS coordinates: latitude 50.67612, longitude -120.35428, altitude 447 m
Mar 22 22:31:42 rak-gateway ttn-gateway[23786]: JSON up: {“stat”:{“time”:“2020-03-22 22:30:42 GMT”,“lati”:50.67612,“long”:-120.35428,“alti”:447,“rxnb”:0,“rxok”:0,“rxfw”:0,“ackr”:100.0,“dwnb”:0,“txnb”:0}}
Mar 22 22:31:42 rak-gateway ttn-gateway[23786]: INFO: Received pkt from mote: 00000000 (fcnt=0)
Mar 22 22:31:42 rak-gateway ttn-gateway[23786]: JSON up: {“rxpk”:[{“tmst”:1976151284,“time”:“2020-03-22T22:31:04.901468Z”,“tmms”:1268951483901,“chan”:6,“rfch”:1,“freq”:905.100000,“stat”:1,“modu”:“LORA”,“datr”:“SF9BW125”,“codr”:“4/5”,“lsnr”:12.5,“rssi”:-43,“size”:23,“data”:“AAAAAAAAAAAAWVMWDK8B6G3NVXmiXlw=”}]}
Mar 22 22:31:42 rak-gateway ttn-gateway[23786]: INFO: [down] PULL_RESP received - token[46:133]
Mar 22 22:31:42 rak-gateway ttn-gateway[23786]: JSON down: {“txpk”:{“imme”:false,“rfch”:0,“powe”:14,“ant”:0,“brd”:0,“tmst”:1981151284,“freq”:905.1,“modu”:“LORA”,“datr”:“SF9BW125”,“codr”:“4/5”,“ipol”:true,“size”:33,“data”:“IEXHrcbvs9LABNx9XtcBYm8gYyKvF5cNb4cUXheOByb8”}}
Mar 22 22:31:42 rak-gateway ttn-gateway[23786]: INFO: tx_start_delay=1495 (1495.500000) - (1497, bw_delay=1.500000, notch_delay=0.000000)
Mar 22 22:31:42 rak-gateway ttn-gateway[23786]: INFO: Received pkt from mote: C6ADC745 (fcnt=53939)
Mar 22 22:31:42 rak-gateway ttn-gateway[23786]: JSON up: {“rxpk”:[{“tmst”:1981398052,“time”:“2020-03-22T22:31:10.148235Z”,“tmms”:1268951489148,“chan”:5,“rfch”:1,“freq”:904.900000,“stat”:1,“modu”:“LORA”,“datr”:“SF9BW125”,“codr”:“4/5”,“lsnr”:2.5,“rssi”:-101,“size”:33,“data”:“IEXHrcbvs9LABNx9XtcBYm8gYyKvF5cNb4cUXheOByb8”}]}
Mar 22 22:31:42 rak-gateway ttn-gateway[23786]: INFO: Disabling GPS mode for concentrator’s counter…
Mar 22 22:31:42 rak-gateway ttn-gateway[23786]: INFO: host/sx1301 time offset=(1584914289s:753790µs) - drift=50µs
Mar 22 22:31:42 rak-gateway ttn-gateway[23786]: INFO: Enabling GPS mode for concentrator’s counter.
Mar 22 22:31:42 rak-gateway ttn-gateway[23786]: ##### 2020-03-22 22:31:12 GMT #####
Mar 22 22:31:42 rak-gateway ttn-gateway[23786]: # RF packets received by concentrator: 2
Mar 22 22:31:42 rak-gateway ttn-gateway[23786]: # CRC_OK: 100.00%, CRC_FAIL: 0.00%, NO_CRC: 0.00%
Mar 22 22:31:42 rak-gateway ttn-gateway[23786]: # RF packets forwarded: 2 (56 bytes)
Mar 22 22:31:42 rak-gateway ttn-gateway[23786]: # PUSH_DATA datagrams sent: 3 (700 bytes)
Mar 22 22:31:42 rak-gateway ttn-gateway[23786]: # PULL_RESP(onse) datagrams received: 1 (214 bytes)
Mar 22 22:31:42 rak-gateway ttn-gateway[23786]: # RF packets sent to concentrator: 1 (33 bytes)
Mar 22 22:31:42 rak-gateway ttn-gateway[23786]: # TX rejected (collision packet): 0.00% (req:2, rej:0)
Mar 22 22:31:42 rak-gateway ttn-gateway[23786]: # TX rejected (collision beacon): 0.00% (req:2, rej:0)
Mar 22 22:31:42 rak-gateway ttn-gateway[23786]: # TX rejected (too late): 0.00% (req:2, rej:0)
Mar 22 22:31:42 rak-gateway ttn-gateway[23786]: # TX rejected (too early): 0.00% (req:2, rej:0)
Mar 22 22:31:42 rak-gateway ttn-gateway[23786]: # SX1301 time (PPS): 1982771220
Mar 22 22:31:42 rak-gateway ttn-gateway[23786]: # GPS coordinates: latitude 50.67614, longitude -120.35431, altitude 446 m
Mar 22 22:31:42 rak-gateway ttn-gateway[23786]: JSON up: {“stat”:{“time”:“2020-03-22 22:31:12 GMT”,“lati”:50.67614,“long”:-120.35431,“alti”:446,“rxnb”:2,“rxok”:2,“rxfw”:2,“ackr”:100.0,“dwnb”:1,“txnb”:1}}
Mar 22 22:33:12 rak-gateway ttn-gateway[23786]: INFO: [down] PULL_ACK received in 0 ms
Mar 22 22:33:12 rak-gateway ttn-gateway[23786]: ##### 2020-03-22 22:31:42 GMT #####
Mar 22 22:33:12 rak-gateway ttn-gateway[23786]: ### [UPSTREAM] ###
Mar 22 22:33:12 rak-gateway ttn-gateway[23786]: # RF packets received by concentrator: 2
Mar 22 22:33:12 rak-gateway ttn-gateway[23786]: # CRC_OK: 0.00%, CRC_FAIL: 100.00%, NO_CRC: 0.00%
Mar 22 22:33:12 rak-gateway ttn-gateway[23786]: # RF packets forwarded: 0 (0 bytes)
Mar 22 22:33:12 rak-gateway ttn-gateway[23786]: # PUSH_DATA datagrams sent: 1 (158 bytes)
Mar 22 22:33:12 rak-gateway ttn-gateway[23786]: # PUSH_DATA acknowledged: 100.00%
Mar 22 22:33:12 rak-gateway ttn-gateway[23786]: ### [DOWNSTREAM] ###
Mar 22 22:33:12 rak-gateway ttn-gateway[23786]: # PULL_DATA sent: 3 (100.00% acknowledged)
Mar 22 22:33:12 rak-gateway ttn-gateway[23786]: # PULL_RESP(onse) datagrams received: 0 (0 bytes)
Mar 22 22:33:12 rak-gateway ttn-gateway[23786]: # RF packets sent to concentrator: 0 (0 bytes)
Mar 22 22:33:12 rak-gateway ttn-gateway[23786]: # TX errors: 0
Mar 22 22:33:12 rak-gateway ttn-gateway[23786]: # TX rejected (collision packet): 0.00% (req:2, rej:0)
Mar 22 22:33:12 rak-gateway ttn-gateway[23786]: # TX rejected (collision beacon): 0.00% (req:2, rej:0)
Mar 22 22:33:12 rak-gateway ttn-gateway[23786]: # TX rejected (too late): 0.00% (req:2, rej:0)
Mar 22 22:33:12 rak-gateway ttn-gateway[23786]: # TX rejected (too early): 0.00% (req:2, rej:0)
Mar 22 22:33:12 rak-gateway ttn-gateway[23786]: # BEACON queued: 0
Mar 22 22:33:12 rak-gateway ttn-gateway[23786]: # BEACON sent so far: 0
Mar 22 22:33:12 rak-gateway ttn-gateway[23786]: # BEACON rejected: 0
Mar 22 22:33:12 rak-gateway ttn-gateway[23786]: ### [JIT] ###
Mar 22 22:33:12 rak-gateway ttn-gateway[23786]: # SX1301 time (PPS): 2012249820
Mar 22 22:33:12 rak-gateway ttn-gateway[23786]: src/jitqueue.c:448:jit_print_queue(): INFO: [jit] queue is empty
Mar 22 22:33:12 rak-gateway ttn-gateway[23786]: ### [GPS] ###
Mar 22 22:33:12 rak-gateway ttn-gateway[23786]: # Valid time reference (age: 0 sec)
Mar 22 22:33:12 rak-gateway ttn-gateway[23786]: # GPS coordinates: latitude 50.67614, longitude -120.35432, altitude 449 m
Mar 22 22:33:12 rak-gateway ttn-gateway[23786]: ##### END #####
Mar 22 22:33:12 rak-gateway ttn-gateway[23786]: JSON up: {“stat”:{“time”:“2020-03-22 22:31:42 GMT”,“lati”:50.67614,“long”:-120.35432,“alti”:449,“rxnb”:2,“rxok”:0,“rxfw”:0,“ackr”:100.0,“dwnb”:0,“txnb”:0}}
Mar 22 22:33:12 rak-gateway ttn-gateway[23786]: INFO: [up] PUSH_ACK received in 0 ms
Mar 22 22:33:12 rak-gateway ttn-gateway[23786]: INFO: Disabling GPS mode for concentrator’s counter…
Mar 22 22:33:12 rak-gateway ttn-gateway[23786]: INFO: host/sx1301 time offset=(1584914289s:753842µs) - drift=52µs
Mar 22 22:33:12 rak-gateway ttn-gateway[23786]: INFO: Enabling GPS mode for concentrator’s counter.
Mar 22 22:33:12 rak-gateway ttn-gateway[23786]: ##### 2020-03-22 22:32:12 GMT #####
Mar 22 22:33:12 rak-gateway ttn-gateway[23786]: # RF packets received by concentrator: 0
Mar 22 22:33:12 rak-gateway ttn-gateway[23786]: # CRC_OK: 0.00%, CRC_FAIL: 0.00%, NO_CRC: 0.00%
Mar 22 22:33:12 rak-gateway ttn-gateway[23786]: # SX1301 time (PPS): 2042771596
Mar 22 22:33:12 rak-gateway ttn-gateway[23786]: # GPS coordinates: latitude 50.67613, longitude -120.35431, altitude 450 m
Mar 22 22:33:12 rak-gateway ttn-gateway[23786]: JSON up: {“stat”:{“time”:“2020-03-22 22:32:12 GMT”,“lati”:50.67613,“long”:-120.35431,“alti”:450,“rxnb”:0,“rxok”:0,“rxfw”:0,“ackr”:100.0,“dwnb”:0,“txnb”:0}}
Mar 22 22:33:12 rak-gateway ttn-gateway[23786]: ##### 2020-03-22 22:32:42 GMT #####
Mar 22 22:33:12 rak-gateway ttn-gateway[23786]: # PULL_DATA sent: 2 (100.00% acknowledged)
Mar 22 22:33:12 rak-gateway ttn-gateway[23786]: # SX1301 time (PPS): 2072249827
Mar 22 22:33:12 rak-gateway ttn-gateway[23786]: # GPS coordinates: latitude 50.67612, longitude -120.35432, altitude 455 m
Mar 22 22:33:12 rak-gateway ttn-gateway[23786]: JSON up: {“stat”:{“time”:“2020-03-22 22:32:42 GMT”,“lati”:50.67612,“long”:-120.35432,“alti”:455,“rxnb”:0,“rxok”:0,“rxfw”:0,“ackr”:100.0,“dwnb”:0,“txnb”:0}}
Mar 22 22:33:12 rak-gateway ttn-gateway[23786]: INFO: host/sx1301 time offset=(1584914289s:753887µs) - drift=45µs
