Hi Friends!
v4.0.0 /api seemingly provides pre-built grpc files to use in go project (/api/go
subfolder).
However I’m a bit lost how to import it in my project. Neither
import "github.com/chirpstack/chirpstack/v4/api/go/api"
nor
import "github.com/chirpstack/chirpstack/api/go/api"
would work
If I try directly go get
, e.g.:
go get github.com/chirpstack/chirpstack@v4.0.0
Then downloaded module is v4.0.0+incompatible
and it lacks go
subfolder
Thanks in advance for all the hints and clues!
bconway
#2
Your first import looks correct, see:
https://www.chirpstack.io/docs/chirpstack/api/go-examples.html
If your IDE isn’t automatically downloading the dependencies for you, you should be able to use go get
with the same line.
Great, thanks a lot!
Obviously I should learn go dependencies/versioning better
It is just about properly writing the import
"github.com/chirpstack/chirpstack/api/go/v4/api"
then go get
works like a charm (for I had a scratch test in notepad) and as you mentioned should work seamlessly in any mighty IDE.
Thank you very much!
system
Closed
#4
