anyone else face the issue that the gateway name is missing in rxInfo?:
Before the migration from v3 to v4 the gateway name was a part of rxInfo.
Is there a chance to manually edit the meta data from each gw to add the name this way?
The gateway name was already dropped in the latest v3 version, please see the v3 UplinkRxInfo definition here:
with no result - for what exactly is the tag option?
Some companies integrated ChirpStack into their own platform (using the API) and in some cases they need to store additional key / value data in the gateway object. The tags feature makes this possible
in this case i didnt run the latest v3 Sorry.
So there will be no opt-in to activate gateway name again?
Tags are only available via the api then if i got it right?
Main reason is to save the gw name in the db for better readability, without the gw name in the packet, there must be an additional query - maybe via api?!
Thanks for your answer - and so far v4 works like a charm, great work!
