Hi everybody,
as I am working on an Chirpstack LoRaWAN adapter for a DLT I would like to control the Application Server by using a gRPC stub which works great by the way.
However I came across the following comment in the device.proto file which I use to stream any uplink events:
// StreamFrameLogs streams the uplink and downlink frame-logs for the given DevEUI.
// * These are the raw LoRaWAN frames and this endpoint is intended for debugging only.
// * This endpoint does not work from a web-browser.
** rpc StreamFrameLogs(StreamDeviceFrameLogsRequest) returns (stream StreamDeviceFrameLogsResponse)**
Why should I use this service for debugging only? Is this a security issue?
In the past I have used MQTT Clients to subscribe to those events, but would prefer to make my own C++ integration.
Thanks for you help.
Regards
emDave
