Hello everyone ,
i was just wondering , as you can see bellow , the date and time mentioned in any of my UpLink messages are wrong even though the time on the log frames is correct .
How can i fix this please ?
Hello everyone ,
Maybe the date is wrong because the date time of the Gateway is different. What type of gw are you using?
Hello
I’m using Dragino LPS8 gateway
Ok. I use also Dragino. The problem maybe is the date time of the hardware of the GW. Can you configure manual using SSH and later change the time using linux commands.
Or can configure NTP client for take automatic date time in the file configuration /etc/config/system and change “system.ntp.server” and later restart this service “/etc/init.d/sysntpd”. Also in SSH
