chirpstack-concentratord 2022-08-05 14:20:00,670 INFO [libconcentratord::events] Publishing stats event, rx_received: 1, rx_received_ok: 1, tx_received: 0, tx_emitted: 0
chirpstack-gateway-bridge INFO[0021] backend/concentratord: stats event received stats_id=00000000-0000-0000-0000-000000000000
chirpstack-gateway-bridge INFO[0021] integration/mqtt: publishing event event=stats qos=0 stats_id=00000000-0000-0000-0000-000000000000 topic=gateway/0000000000000000/event/stats
chirpstack-gateway-bridge DEBU[0021] [client] enter Publish module=mqtt
chirpstack-gateway-bridge DEBU[0021] [client] sending publish message, topic: gateway/0000000000000000/event/stats module=mqtt
Hello, I am building a docker setup with concentratord and gateway-bridge running in different containers, and communicating between a shared volume folder. However the event data appear to be zero, while concentratord logs report correct gateway id.
chirpstack-gateway-bridge.toml:
# This configuration provides a Semtech UDP packet-forwarder backend and
# integrates with a MQTT broker. Many options and defaults have been omitted
# for simplicity.
# See https://www.chirpstack.io/gateway-bridge/install/config/ for a full
# configuration example and documentation.
[general]
log_level=5
# Log to syslog.
# When set to true, log messages are being written to syslog.
log_to_syslog=false
[backend]
# Backend type.
type="concentratord"
# ChirpStack Concentratord backend.
[backend.concentratord]
# Check for CRC OK.
crc_check=true
# Event API URL.
event_url="ipc:///tmp/zeromq/concentratord_event"
# Command API URL.
command_url="ipc:///tmp/zeromq/concentratord_command"
# Integration configuration.
[integration]
# Payload marshaler.
# This defines how the MQTT payloads are encoded. Valid options are:
# * protobuf: Protobuf encoding (this will become the LoRa Gateway Bridge v3 default)
# * json: JSON encoding (easier for debugging, but less compact than 'protobuf')
marshaler="protobuf"
# MQTT integration configuration.
[integration.mqtt]
# Event topic template.
event_topic_template="gateway/{{ .GatewayID }}/event/{{ .EventType }}"
# Command topic template.
command_topic_template="gateway/{{ .GatewayID }}/command/#"
# MQTT authentication.
[integration.mqtt.auth]
# Type defines the MQTT authentication type to use.
type="generic"
# Generic MQTT authentication.
server="tcp://192.168.1.15:1883"
username=""
password=""
global.toml
# Concentratord configuration.
[concentratord]
# Log level.
# Valid options are:
# * TRACE
# * DEBUG
# * INFO
# * WARN
# * ERROR
# * OFF
log_level="DEBUG"
# Log to syslog.
# When set to true, log messages are being written to syslog instead of stdout.
log_to_syslog=false
# Statistics interval.
stats_interval="30s"
# Configuration for the (ZeroMQ based) API.
[concentratord.api]
# Event PUB socket bind.
event_bind="ipc:///tmp/zeromq/concentratord_event"
# Command REP socket bind.
command_bind="ipc:///tmp/zeromq/concentratord_command"
# LoRa gateway configuration.
[gateway]
# Antenna gain (dB).
antenna_gain=0
# Public LoRaWAN network.
lorawan_public=true
# Gateway vendor / model.
# This configures various vendor and model specific settings like the min / max
# frequency, TX gain table.
model="rak_2287_eu868"
# Gateway vendor / model flags.
model_flags=["GNSS",]
