Hi ,
So I have got a few issues regarding Gateway OS. Since I have installed Gateway OS for IMST iC880A board which supports a 4G Modem. I was wondering how can I enable 4G inside the Gateway OS?
I did the necessary steps by adding ppp to the Gateway OS image. After this I was able to access the ppp
utlitity, and using AT commands
I was also successful in switching on the 4G Modem. Through a script, I was able to run the ppp0
interface, as on checking through ifconfig
command, it showed ppp0
interface was up and running and also an IP address was allotted to it.
But the internet through the 4G did not turn ON i.e. I could not ssh
through that allotted IP and also ppp0
was not receiving or sending any packets. Also, ppp0
was not able to ping
to any IP.
If anybody can give me a solution for this, that would be great!
Thank you!
