I’ve set up ChirpStack v4 on AWS Elastic Beanstalk (load balanced environment), and when accessing the LoRaWAN frames tab on a Gateway the data never loads. I looked into the brower’s developer tools and I found that the request is failing with a 504 Gateway Time-out error.
My suspicion is that the request is actually never reaching the EC2 instance. My reasoning:
- From the request headers I’m deducing that the request is being sent through gRPC
- The load balancer is an Application Load Balancer
- The Load Balancer Listener is using port 80 (HTTP)
- The Load Balancer Target Group is using protocol version HTTP (which means HTTP/1.1)
- HTTP/1.1 is not compatible with gRPC
Acting on that suspicion, I’ve tried:
- Creating a Listener on port 443 (HTTPS)
- Creating a Target Group using protocol version HTTP2 (HTTP/2, partially compatible with gRPC) or with protocol version gRPC
- Setting healthcheck to / or to /health
- Registering my EC2 instance on that Target Group
The problem is that the Target Group is marking my instance as unhealthy (failed healthcheck), so it’s never sending traffic to it (the result is a 502 error, consistent with my AWS experience of a Target Group with no healthy instances).
I would greatly appreciate if someone could tell me how to perform healthchecks with a Target Group configured for HTTP2 or gRPC.
Or alternatively, if I’m completely mistaken and how I could resolve this.
For reference, this worked in ChirpStack v3, and I suspect it was because the Application server only used HTTP (I could be wrong on this).
Things that I am considering:
- Replacing the Application Load Balancer with a Network Load Balancer. The problem is that a Network Load Balancer won’t decrypt HTTPS traffic, so if I want to expose ChirpStack through HTTPS I need to do it some other way.
