Brocaar, in front, thanks a lot for your work!!
We want to connect 8 channel and 16 channel LoraGWs on the Lora-App-Server with two Loraservers.
Do you see a problem in following architecture?
With the information provided, I don’t see any issues.
But the sensors registered at AppServer should be able to use both networks depending which signal is stronger.
