Hi ,
I am getting below mentioned log at times.
ERRO[0256] gateway: tx ack received error=“TOO_EARLY” mac=00000001ffff0051 random_token=0
Can you please comment in what condition causes such message
Hi ,
Please see the explanation at the bottom of this page: https://www.loraserver.io/lora-gateway-bridge/use/data/.
Hello Brocaar,
I read the documentation that you pointed. If the packet was rejected, it is not transmitted by the gateway, right? This problem is caused by a bad configuration? Maybe RX_DELAY?
Thanks in advance!
The issue is probably the latency between your gateway and the network. Because of that, the TX timestamp already expired.
