I’m trying to activate a Dragino LHT65 using Chirpstack Gateway OS on a Raspberry Pi 3 B+.
If I do not want to use TTN and internet and just want to see data locally, can I still use OTAA?
Tried boith ways, but can’t get past the activation requests being sent.
Were you able to make it work? I just purchased an LHT65 and I can’t seem to get it to join either. I see the Join Request and Response in the logs but I never see it show up in the dashboard.
Jan 11 15:11:30 R710 chirpstack-network-server[2935]: time=“2022-01-11T15:11:30.063571755-06:00” level=info msg=“gateway/mqtt: uplink frame received” gateway_id=a84041ffff210f0c uplink_id=25fd8f87-3fbe-469c-8a8d-959732ea1478
Jan 11 15:11:30 R710 chirpstack-network-server[2935]: time=“2022-01-11T15:11:30.265590746-06:00” level=info msg=“uplink: frame(s) collected” ctx_id=63bd0484-8426-4f7e-9d82-46cb4e6c6107 mtype=JoinRequest uplink_ids="[25fd8f87-3fbe-469c-8a8d-959732ea1478]"
Jan 11 15:11:30 R710 chirpstack-network-server[2935]: time=“2022-01-11T15:11:30.265876379-06:00” level=error msg=“uplink: log uplink frames for gateways error” ctx_id=63bd0484-8426-4f7e-9d82-46cb4e6c6107 error=“redis xadd error: EXECABORT Transaction discarded because of previous errors.”
Jan 11 15:11:30 R710 chirpstack-network-server[2935]: time=“2022-01-11T15:11:30.268344268-06:00” level=error msg=“log uplink frame for device error” ctx_id="" error=“redis xadd error: EXECABORT Transaction discarded because of previous errors.”
Jan 11 15:11:30 R710 chirpstack-network-server[2935]: time=“2022-01-11T15:11:30.276622738-06:00” level=info msg=“lorawan/backend: finished backend api call” message_type=JoinReq protocol_version=1.0 receiver_id=a840410000000100 result_code=Success sender_id=000000 transaction_id=3301925626
Jan 11 15:11:30 R710 chirpstack-network-server[2935]: time=“2022-01-11T15:11:30.276683838-06:00” level=info msg=“sent uplink meta-data to network-controller” ctx_id=63bd0484-8426-4f7e-9d82-46cb4e6c6107 dev_eui=a8404131a184410d
Jan 11 15:11:30 R710 chirpstack-network-server[2935]: time=“2022-01-11T15:11:30.277199066-06:00” level=info msg=“device-queue flushed” ctx_id=63bd0484-8426-4f7e-9d82-46cb4e6c6107 dev_eui=a8404131a184410d
Jan 11 15:11:30 R710 chirpstack-network-server[2935]: time=“2022-01-11T15:11:30.277671514-06:00” level=info msg=“device-session saved” ctx_id=63bd0484-8426-4f7e-9d82-46cb4e6c6107 dev_addr=01ae2f80 dev_eui=a8404131a184410d
Jan 11 15:11:30 R710 chirpstack-network-server[2935]: time=“2022-01-11T15:11:30.344430042-06:00” level=info msg=“device-activation created” ctx_id=63bd0484-8426-4f7e-9d82-46cb4e6c6107 dev_eui=a8404131a184410d id=5
Jan 11 15:11:30 R710 chirpstack-network-server[2935]: time=“2022-01-11T15:11:30.404622125-06:00” level=info msg=“device updated” ctx_id=63bd0484-8426-4f7e-9d82-46cb4e6c6107 dev_eui=a8404131a184410d
Jan 11 15:11:30 R710 chirpstack-network-server[2935]: time=“2022-01-11T15:11:30.404766583-06:00” level=info msg=“gateway/mqtt: publishing gateway command” command=down downlink_id=63bd0484-8426-4f7e-9d82-46cb4e6c6107 gateway_id=a84041ffff210f0c qos=0 topic=gateway/a84041ffff210f0c/command/down
Jan 11 15:11:30 R710 chirpstack-network-server[2935]: time=“2022-01-11T15:11:30.405073501-06:00” level=info msg=“storage: downlink-frame saved” ctx_id=63bd0484-8426-4f7e-9d82-46cb4e6c6107 token=54921
Jan 11 15:11:30 R710 chirpstack-network-server[2935]: time=“2022-01-11T15:11:30.412396479-06:00” level=info msg=“backend/gateway: downlink tx acknowledgement received” downlink_id=63bd0484-8426-4f7e-9d82-46cb4e6c6107 gateway_id=a84041ffff210f0c
Jan 11 15:11:30 R710 chirpstack-network-server[2935]: time=“2022-01-11T15:11:30.413117967-06:00” level=info msg=“sent downlink meta-data to network-controller” ctx_id=63bd0484-8426-4f7e-9d82-46cb4e6c6107
Jan 11 15:11:30 R710 chirpstack-network-server[2935]: time=“2022-01-11T15:11:30.41323841-06:00” level=error msg=“log downlink frame for gateway error” ctx_id=63bd0484-8426-4f7e-9d82-46cb4e6c6107 error=“redis xadd error: EXECABORT Transaction discarded because of previous errors.”
Jan 11 15:11:30 R710 chirpstack-network-server[2935]: time=“2022-01-11T15:11:30.413457094-06:00” level=error msg=“log downlink frame for device error” ctx_id=63bd0484-8426-4f7e-9d82-46cb4e6c6107 error=“redis xadd error: EXECABORT Transaction discarded because of previous errors.”
Jan 11 15:11:30 R710 chirpstack-application-server[2922]: time=“2022-01-11T15:11:30.269824209-06:00” level=info msg=“backend/joinserver: request received” message_type=JoinReq receiver_id=a840410000000100 sender_id=000000 transaction_id=3301925626
Jan 11 15:11:30 R710 chirpstack-application-server[2922]: time=“2022-01-11T15:11:30.276383831-06:00” level=info msg=“device-keys updated” ctx_id="" dev_eui=a8404131a184410d
Jan 11 15:11:30 R710 chirpstack-application-server[2922]: time=“2022-01-11T15:11:30.276436309-06:00” level=info msg=“backend/joinserver: sending response” dev_eui=a8404131a184410d message_type=JoinAns receiver_id=000000 result_code=Success sender_id=a840410000000100 transaction_id=3301925626
Jan 11 15:11:30 R710 chirpstack-gateway-bridge[2949]: time=“2022-01-11T15:11:30.063229782-06:00” level=info msg=“integration/mqtt: publishing event” event=up qos=0 topic=gateway/a84041ffff210f0c/event/up uplink_id=25fd8f87-3fbe-469c-8a8d-959732ea1478
Jan 11 15:11:30 R710 chirpstack-gateway-bridge[2949]: time=“2022-01-11T15:11:30.405110413-06:00” level=info msg=“integration/mqtt: downlink frame received” downlink_id=63bd0484-8426-4f7e-9d82-46cb4e6c6107 gateway_id=a84041ffff210f0c
Jan 11 15:11:30 R710 chirpstack-gateway-bridge[2949]: time=“2022-01-11T15:11:30.411937899-06:00” level=info msg=“integration/mqtt: publishing event” downlink_id=63bd0484-8426-4f7e-9d82-46cb4e6c6107 event=ack qos=0 topic=gateway/a84041ffff210f0c/event/ack
