i prepare a bigger migration from Chirpstack v3 to v4,
i used this guide (v3 to v4 migration - ChirpStack open-source LoRaWAN® Network Server documentation).
But after a successful run of the tool the device activation was not migrated, is this a error or a bug?
Did i there something wrong?
I’ve seen no error message or something more, at this point i prepare the migration so i could rerun the migration.
By the way, is the activation entry in the postgre database or in the redis database?
i let a few different Migrations run, everytime with the same result.
The Devices would be created and all settings correctly imporated, but i have to activate each device again.
But i have a few thousands of device so im not able to activate each device by hand.
Is there a way to migrate the activation state or did i something wrong on the migration?
The script should migrate all the device-sessions (that can be found) such that devices will continue to work.
If this doesn’t work, I suggest trying to isolate the issue. E.g. do a test migration of an environment where you have a single device to see if the device-migration has been migrated and if not, if the migration script logged any errors.
