Hello! I came across the problem after upgrading the App Server from the old version 0.15.0.
I can not add the second Network Server using UI.
I want to use different servers to test different regional parameters, but the same application server.
When I try to add the server the system alerts:
“Error context deadline exceeded (code: 2)” if the server is offline
“Error rpc error: code = AlreadyExists desc = object already exists (code: 2)” if the server is online.
It does not matter, if the first server is online or not, it just do not allow to add extra server.
The first server: localhost:8000
The second server: localhost:9000
Is it normal?
UPD. Current versions: app server 1.0.1, network server 1.0.0.
