I’m trying to develop a few scripts that will help me detect various points of failure between the gateway and the server so that I can restart the packet-forwarder and gateway-bridge whenever frames are failing to make it to the server (which we’ve encountered amid network failures outside of chirpstack, requiring us to manually restart the services).
I was curious if there’s a good built-in way to do some of this.
I understand that I can add commands to the configuration file (TOML), but I cannot seem to invoke them from command line. Perhaps MQTT would work? That is my next step. I understand I can also run commands for the packet forwarder if I use the ‘raw’ command, though this does not work from CLI. I can only run a few commands (configfile, version, help) from CLI, although I can see the entries for custom commands when I run the ‘configfile’ command, so I know that my local edits to the TOML file are being recognized once I restart the gateway-bridge service.
Is there something I am missing when I try to add commands to the gateway-bridge? I have included the contents of /etc/chirpstack-gateway-bridge/chirpstack-gateway-bridge.toml below. Attempting to run
chirpstack-gateway-bridge test yields an error, stating "FATA[0000] unknown command “test” for “chirpstack-gateway-bridge” "=
Gateway backend configuration.
[backend]
# Backend type.
type="semtech_udp"
# Semtech UDP packet-forwarder backend.
[backend.semtech_udp]
# ip:port to bind the UDP listener to
# Example: 0.0.0.0:1700 to listen on port 1700 for all network interfaces.
# This is the listener to which the packet-forwarder forwards its data
# so make sure the 'serv_port_up' and 'serv_port_down' from your
# packet-forwarder matches this port.
udp_bind = "localhost:1700"
# Integration configuration.
[integration]
# Payload marshaler.
# This defines how the MQTT payloads are encoded. Valid options are:
# * protobuf: Protobuf encoding
# * json: JSON encoding (easier for debugging, but less compact than 'protobuf')
marshaler="protobuf"
# MQTT integration configuration.
[integration.mqtt]
# Event topic template.
event_topic_template="gateway/{{ .GatewayID }}/event/{{ .EventType }}"
# Command topic template.
command_topic_template="gateway/{{ .GatewayID }}/command/#"
# MQTT authentication.
[integration.mqtt.auth]
# Type defines the MQTT authentication type to use.
# Set this to the name of one of the sections below.
type="generic"
# Generic MQTT authentication.
server="tcp://123.45.67.89:1883"
# server = "tcp://chirpstack.openchirp.io:8883"
username=""
More broadly, I would certainly appreciate if someone more familiar with chirpstack could recommend a good way for checking that the packet-forwarder and gateway-bridge are working correctly. I am of course checking basic IP connection with pings.
