Hello
I have a Milesight UG63 that is setup to forward data to my Chirpstack V4 instance, i can see the gateway live and online receiving data
I’ve added my milesight UC300 and its active but not seeing any of the modbus data using this codec > https://github.com/teeradon43/UC300_Decoder/blob/main/src/js/uc300.js
MY question is, i am also using Milesight IOT cloud, when i added my UC300 to chirpstack using the same applicationID its now dropped off my milesight iot cloud system, can i not add both using the same appid?
datnus
September 26, 2023, 7:39am
2
Reboot your node to force a rejoin to Chirpstack.
The problem is, its connecting to chirpstack, but losing connection to milesight iot hub, rebooting did not help
Matthew_Grisewood:
A device can only be activated on a single Network Server. You should never activate a device on two different NS instances.
