We are trying out the ADR feature on version 0.13.2 of the LoRa App Server and can’t seem to get it to work 100%. The ADR field is set to 1 on the server but there is no change on the device end. Looking at the MQTT stream neither is any TX message being sent from the gateway.
When doing a power cycle on the device and rejoining we got the ADR to work. So to the questions:
Is there a need from the server for the device the renew the session i.e perform a new join?
Are there any other conditions that trigger the ADR?
Exactly how experimental is the feature?(There seems to be some conflicting information )
The uplink data frame contains adr: true (this is configured at the device)
The frame-counter is a multiple of the interval value
Hope that helps In case you would like to test out the latest version, that would be much appreciated! In the above link you’ll find the commands to upgrade (should be a couple of minutes work).
We are going to upgrade to the latest server in maybe 1-2 weeks. We have an upcoming deadline relaying on some external tools and integrations built for the old API/gRPC and currently, dont have the time to look at the changes made in the latest update.
I’ll give a shout back here or add my feedback on another thread when we have tried it out.
