Hi all,
I was looking for cheap options for a LoRaWAN compliant gateway (multichannel and so on).
I am actually using a fipy board as a forwarder but i would like to work with something more stable and that is actually designed to do the job. Searching the Internet i found different options but the one that i liked the most (Raspberry Pi + RAK833 isn’t the cheapest, and also, Raspberry Pis in EU aren’t in stock basically anywhere.
I’m open to explore all the different options that come to mind and every little advice is appreciated.
On the node side I am using a Raspberry Pi Pico with a Waveshare sx1262 HAT and it works just fine with the FiPy board, after tweaking a bit the parameters for the connection.
