Appreciate if someone could guide me on what am I missing.
after activated MQTT integration to external MQTT broker, I can see data send out from Chirpstack to my external MQTT broker but Chipstack failed to receive payload from device.
Hi!
You have got a page called “CODEC” in your device profile. In order to use MQTT external broker, you need to CODE and DECODE the messages going UP and DOWN.
I mean, you need to create a proper CODE function which sends the data to your external MQTT broker in a way is readable for it.
On the other hand, you need to input a DECODE function, so that the data coming from your external MQTT is readable and useful for Chirpstack. (Otherwise, the downlink would not work properly).
Whish I helped you,
Nicolas
Leave you here an example on the CODE function:
result = {};
if(bytes[0] == 2) // Command code = 2
result.address = byteArrayToInt(bytes,1,4);
result.volumen = byteArrayToInt(bytes,5,4);
result.batteryLevel = byteArrayToInt(bytes,15,2);
return result;
function byteArrayToInt(byteArray,n,m)
var val = 0;
for(var i = 0; i < m-1; i++)
val += byteArray[i+n] << i * 7;
return val;
Hi Nicolas,
Thanks for your guidance, however, i’m still little confuse. Do I still need to fill in the broker address for connect to external broker? on below configuration?
Currently, my problem is whenever I replace the below address to driver.cloudmqtt.com with login credential username and password, Chirpstack will not able to let device to join and receive data.
if I put the address back to localhost, without any login credential, then Chirpstack back to normal and let device to join and receive payload from device. So i was wonder how would this affect Chirpstack to receive data from device if after fill the external broker address with login details.
Generic MQTT authentication.
MQTT server (e.g. scheme://host:port where scheme is tcp, ssl or ws)
server=“tcp://127.0.0.1:1883”
Connect with the given username (optional)
username=“”
Connect with the given password (optional)
password=“”
If things goes fine using localhost as tcp address, I think you may be doing something wrong using your own name. What I did to have my Chirpstack server working on any http address I wanted to, is entering the Gateway configuration (via UI), then change the http address and fix it in a free domain (ex: http://myservernamehere.com)
server=“http://driver.cloudmqtt.com:18745”
I had try to fill in like the above, and it still same, after fill with external broker address, the gateway became inactive in Chirpstack.
I saw you mentioned "entering the gateway configuration (via UI)? I can’t find where I can change this configuration via UI, my Chirpstack version is 4.0.2, would like to seek for your advise.
Hi
I am using version 4 of chirpstack and also I have generated all the certificates, provided path in the toml file of chirpstack and also tried using gateway.toml file but still in the MQTT Integration I am recieving an error
''read mqtt ca_cert" how did you fixed it?
Hi all,
I meant to enter your gateway user interface (UI) via http. For example if your gateway has got the address 10.120.0.1 then you should enter in any browser: “http://10.120.0.1” and then you can do your gateway configuration.
Inside it, you can fix a tcp address for your server. (In other words you are setting your “localhost” to work on another address different from 127.0.0.1 (default)).
