Good night.
When I’ve tried to send a downlink to an end device connected to MikroTik wAP LR9 with the Network Server ChirpStack, I saw the following error on Device Data:
error: “TX_FREQ”.
Someone nows what this error is?
I don’t know what to do, and nothing on the foruns solved my problem.
Tnks
Hello!
Thank you
But how can I know de downlink frequency being requested? And how can I change it?
If you are using UDP forwarder the global conf has tx min/max for allow tx range. The gw will validate the requested frequency is in range.
"SX1301_conf": {
"lorawan_public": true,
"clksrc": 1, /* radio_1 provides clock to concentrator */
"lbt_cfg": {
"enable": false,
"rssi_target": -80, /* dBm */
"chan_cfg":[ /* 8 channels maximum */
{ "freq_hz": 867100000, "scan_time_us": 128 },
{ "freq_hz": 867300000, "scan_time_us": 5000 },
{ "freq_hz": 867500000, "scan_time_us": 128 },
{ "freq_hz": 869525000, "scan_time_us": 128 }
"sx127x_rssi_offset": -4 /* dB */
"antenna_gain": 0, /* antenna gain, in dBi */
"radio_0": {
"enable": true,
"type": "SX1257",
"freq": 867500000,
This file has been truncated. show original
Basic Station will validate based on the region sent from the LNS.
