Does Grafana server + influxDB + ChirpStack Gateway OS full runs on same Raspberry pi that RAK2245 mounted gateway? As you know latest raspberry pi 4 have 8gb ram. I will only monitor about 20-30 nodes.
Thanks
Thanks
It’s probably possible, especially at low volume, but I feel like it would trash the SD card pretty hard.
I use the exaclty same setup but in a Raspberry Pi 2B and it is working fine. However I’m monitoring three devices as mine is still a development test, I would reccomend a remote server for permanent service.
I’m using mine for three months and is still fine.
It has been a while and I wonder if there is a guide how to install Influxdb on Chirpstack OC - I am struggling with the Yocto Linux …
You can install influxdb on docker it works very well.
