I am trying to allow my gateway (Raspberry Pi(4, Debian 12) w/ WM1302) to talk to my Chirpstack server I have set up on my local Linux machine. I can get the two to talk with the Semtech Packet Forwarder provided in the docs for the WM1302, but I am trying to use something else that doesn’t require UDP, as I have had some trouble convincing IT to let us open a port for UDP. I am wondering if anyone else has had any luck with a similar setup?
I am considering whether setting up a gateway bridge on the same Raspberry Pi and pointing the packet forwarder to it would be a good idea or not, or if it might be easier to edit the Packet Forwarder source code and recompile to use something other than UDP.
Thanks in advance!
