What is the planned timing for AMQP integration in Chirpstack v4?
It is already there
# AMQP / RabbitMQ integration configuration.
[integration.amqp]
# Server URL.
# See for a specification of all the possible options:
# https://www.rabbitmq.com/uri-spec.html
url="amqp://guest:guest@localhost:5672"
# Event routing key.
# This is the event routing-key template used when publishing device
# events. Messages will be published to the "amq.topic" exchange.
event_routing_key="application.{{application_id}}.device.{{dev_eui}}.event.{{event}}"
# Use JSON encoding instead of Protobuf (binary).
json=true
https://www.chirpstack.io/docs/chirpstack/configuration.html
Excellent! I asked because the docs say it’s planned for a future release.
Is there more to the [integration.amqp]
section? For example:
- How to define the downlink topic and the queue to consume it from?
- How to determine what exchange events are published to?
- How to set publish options?
Also, is there an example of the message content that is published? And what is expected on a downlink?
Currently it does not provide downlink functionality (neither did the v3 AMQP integration).
I believe it is published to the amq.topic
exchange, on the topic as configured in the config file. Please see for a list of example events: Event types - ChirpStack open-source LoRaWAN® Network Server documentation.
Based on json=true
or json=false
, the payloads are encoded as json or Protobuf.
Ah, OK. Then it’s not really a viable alternative to MQTT. Any thoughts about enhancing the AMQP integration?
