we are currently working on the migration from version 3 to 4. In this transitional period we have both versions running simultaneously in our staging environment.
In RabbitMQ, I need to be able to distinguish which data packets come from which chirpstack version. To do so, I changed the routing key template in the configuration file for Chirpstack V4 as follows:
# Event routing key.
# This is the event routing-key template used when publishing device
# events. Messages will be published to the "amq.topic" exchange.
event_routing_key_template="chirpstack4.application.{{ .ApplicationID }}.device.{{ .DevEUI }}.event.{{ .EventType }}"
Unfortunately, Chirpstack V4 ignores the change and keeps sending data packages with the default routing key
event_routing_key_template="application.{{ .ApplicationID }}.device.{{ .DevEUI }}.event.{{ .EventType }}"
What am I missing here so that Chirpstack uses the desired event_routing_key_template?
Thanks in advance for your support!
Best regards
Chris
