hi,
i’m using app-server v2.0, and when i use an acount which is no global admin , but org admin, i can’t create gateway in UI, because when i select a network-server from list , the api “GET /api/network-servers/{id}” returns a 401 status and redirect me to login page.
is it a bug or something else?
It says your certificate is invalid.
This has nothing to do with being in an admin role or not. Probably you need to refresh and when your browser tells you the the certificate is invalid, either add an exception or configure a proper certificate. See bottom of this page: https://www.loraserver.io/lora-app-server/install/config/.
