LoRa Server v3.0.0-test.1
Features
Improvements
Legacy code removed
Legacy code related to older gateway structures have been removed. All gateway messages are now based on the Protobuf messages.
MQTT topic refactor
Previously, each topic was configured separatly. To be consistent with LoRa Gateway Bridge v3, this has been re-factored into “events” and “commands”.
Upgrading
LoRa Server v3 depends on LoRa Gateway Bridge v3! It is recommended to upgrade to
the latest LoRa Server v2 release (which is forwards compatible with the LoRa Gateway Bridge v3), upgrade all LoRa Gateway Bridge installations to v3 and then upgrade LoRa Server to v3.
It is also recommended to update your LoRa Server configuration file. See Configuration for more information.
Debian / Ubuntu users
Please use the 3.x testing repository:
sudo apt-key adv --keyserver keyserver.ubuntu.com --recv-keys 1CE2AFD36DBCCA00
sudo echo "deb https://artifacts.loraserver.io/packages/3.x/deb testing main" | sudo tee /etc/apt/sources.list.d/loraserver.list
sudo apt-get update
Docker users
Please see the available Docker tags: https://cloud.docker.com/u/loraserver/repository/docker/loraserver/loraserver/tags.
Downloads
Please see: https://artifacts.loraserver.io/downloads/loraserver/.
LoRa Server v3.0.0-test.2
Features
Improvements
Legacy code removed
MQTT topic refactor
Upgrading
LoRa Server v3 depends on LoRa Gateway Bridge v3! It is recommended to upgrade to the latest LoRa Server v2 release (which is forwards compatible with the LoRa Gateway Bridge v3), upgrade all LoRa Gateway Bridge installations to v3 and then upgrade LoRa Server to v3.
LoRa Server v3.0.0-test.3
Features
Improvements
Legacy code removed
messages.
MQTT topic refactor
Azure integration
The Azure integration (Cloud to Device) has been improved.
RXTimingSetupAns acknowledged
When LoRa Server receives a RXTimingSetupAns mac-command, it will always respond to the device, even when this results in sending an empty frame.
Upgrading
