I’m currently running on the 8080 network server and I’m looking to generate an authentification token (API Key).
How would i go about doing this and where would i then access the api key.
I’m also trying to locate the server/port address so that i can set up my network. Any help would be much appreciated. Thank You!
API Keys can be generated through the web interface. Under the network server section click API Keys → Add Api Key. The key can only be retrieved once while generating it and then you should save it elsewhere.
When you say you are trying to locate the server/port, I assume you mean for the API. The API endpoint is the same DNS and port as your web interface.
