One of the clients for the new LoRaWAN network is using third party devices. These devices are pre-programmed with
- DEFAULT_APP_EUI ~ XXXXXXXXXXXXXXXX
- DEFAULT_APP_KEY ~ XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
The app_key (or Join_key) is not a problem. So the crux if my question is: Is there a way that I can make sure that the application has the same app_EUI as the devices, or will this just magically work? I’m only going to use devices with the same app_EUI, as they will have the same data coming out, and will need to have separate end points.
