Hello ChirpStack community ![]()
i got a question regarding the access to the Web UI after the implementation on a Kubernetes Cluster.
I implemented ChirpStack from here GitHub - Mekrache/chirpstack-kubernetes: This repository contains a skeleton to setup the ChirpStack open-source LoRaWAN Network Server stack using kubernetes.
I have implemented it on a Kubernetes Cluster and for further tests on Minikube too. After the implementation, i can not access the Webinterface using the configured NodePorts in both implementations. With the following command i get 3 URL´s with a different port.
minikube service chirpstack-application-server --url -p multinode
when i try to curl them i get the following error for each URL:
curl http://192.168.49.2:30001
curl: (7) Failed to connect to 192.168.49.2 port 30001 after 0 ms: Connection refused
There is also no firewall rule which could forbid the connection. Also when i turn off the firewall completly, it is still not possible.
Does anyone know what the problem could be?
If further informations are needed, i can provide them for sure.
Thanks in advance!
Kind regards
