Application server will not bind web interface on virtual machine
I have Ubuntu 18.04 running on a virtualbox. chirpstack-application-server is running, but the web interface is inaccessible. From netstat, it appears that the service is not even binding the port 8080 on anything.
# This is the API and web-interface exposed to the end-user.
    # ip:port to bind the (user facing) http server to (web-interface and REST / gRPC api)
    bind="0.0.0.0:8080"
# ps aux | grep chirp
appserv+  8858  0.0  0.6 745888 26036 ?        Ssl  20:47   0:00 /usr/bin/chirpstack-application-server
root      8995  0.0  0.0  14428  1100 pts/0    S+   20:56   0:00 grep --color=auto chirp
# netstat -tulpn
Active Internet connections (only servers)
Proto Recv-Q Send-Q Local Address           Foreign Address         State       PID/Program name
tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      535/rpcbind
tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      533/systemd-resolve
tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      2899/cupsd
tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      788/mosquitto
tcp6       0      0 :::111                  :::*                    LISTEN      535/rpcbind
tcp6       0      0 ::1:631                 :::*                    LISTEN      2899/cupsd
tcp6       0      0 :::1883                 :::*                    LISTEN      788/mosquitto
udp        0      0 0.0.0.0:631             0.0.0.0:*                           2901/cups-browsed
udp        0      0 0.0.0.0:711             0.0.0.0:*                           535/rpcbind
udp        0      0 0.0.0.0:5353            0.0.0.0:*                           732/avahi-daemon: r
udp        0      0 0.0.0.0:54630           0.0.0.0:*                           732/avahi-daemon: r
udp        0      0 127.0.0.53:53           0.0.0.0:*                           533/systemd-resolve
udp        0      0 0.0.0.0:68              0.0.0.0:*                           854/dhclient
udp        0      0 0.0.0.0:111             0.0.0.0:*                           535/rpcbind
udp6       0      0 :::711                  :::*                                535/rpcbind
udp6       0      0 :::5353                 :::*                                732/avahi-daemon: r
udp6       0      0 :::56803                :::*                                732/avahi-daemon: r
udp6       0      0 :::111                  :::*                                535/rpcbind
# uname -a
Linux linus-VirtualBox 5.4.0-125-generic #141~18.04.1-Ubuntu SMP Thu Aug 11 20:15:56 UTC 2022 x86_64 x86_64 x86_64 GNU/Linux
Have you checked the logs? That is usually a first good step to debug issues :slight_smile:
