wssq
May 29, 2018, 11:10am
#1
I have a problem in installing “Setup LoRa Server software repository
”. When I run “sudo apt update”
prompt,I got this error
Err:6 https://artifacts.loraserver.io/packages/1.x/deb stable Release
gnutls_handshake() failed: The TLS connection was non-properly terminated.
Reading package lists… Done
E: The repository ‘https artifacts.loraserver.io/packages/1.x/deb stable Release’ does not have a Release file.
N: Updating from such a repository can’t be done securely, and is therefore disabled by default.
N: See apt-secure(8) manpage for repository creation and user configuration details.
I use Ubuntu 16.04.4.
Please help me.
Could you confirm you have the following line in your apt configuration?
deb https://artifacts.loraserver.io/packages/1.x/deb stable main
wssq
May 29, 2018, 12:57pm
#3
Yes ,I have this line in path :"/etc/apt/sources.list.d/loraserver.list".
Are you sure this is not a proxy / firewall issue. I can’t reproduce your issue:
root@iot-test:~# cat /etc/apt/sources.list.d/loraserver.list
root@iot-test:~# apt update
Hit:4 http://ppa.launchpad.net/certbot/certbot/ubuntu xenial InRelease
Hit:1 http://lon1.mirrors.digitalocean.com/ubuntu xenial InRelease
Get:2 http://lon1.mirrors.digitalocean.com/ubuntu xenial-updates InRelease [109 kB]
Get:3 http://lon1.mirrors.digitalocean.com/ubuntu xenial-backports InRelease [107 kB]
Get:5 http://security.ubuntu.com/ubuntu xenial-security InRelease [107 kB]
Get:6 http://apt.postgresql.org/pub/repos/apt xenial-pgdg InRelease [46.5 kB]
Hit:7 https://artifacts.loraserver.io/packages/1.x/deb stable InRelease
Get:8 http://lon1.mirrors.digitalocean.com/ubuntu xenial-updates/main amd64 Packages [783 kB]
Get:9 http://lon1.mirrors.digitalocean.com/ubuntu xenial-updates/universe amd64 Packages [631 kB]
Fetched 1,783 kB in 1s (1,566 kB/s)
Reading package lists... Done
Building dependency tree
Reading state information... Done
3 packages can be upgraded. Run 'apt list --upgradable' to see them.
root@iot-test:~#
wssq
May 29, 2018, 7:39pm
#5
root@ubuntu:/# echo $http_proxy
root@ubuntu:/# sudo ufw status
Status: inactive
root@ubuntu:/# apt update
Get:1 http://archive.ubuntu.com/ubuntu xenial InRelease [247 kB]
Hit:2 http://archive.canonical.com/ubuntu xenial InRelease
Ign:3 https://artifacts.loraserver.io/packages/1.x/deb stable InRelease
Get:4 http://archive.ubuntu.com/ubuntu xenial-updates InRelease [109 kB]
Get:5 http://archive.ubuntu.com/ubuntu xenial-backports InRelease [107 kB]
Get:6 http://archive.ubuntu.com/ubuntu xenial-security InRelease [107 kB]
Err:7 https://artifacts.loraserver.io/packages/1.x/deb stable Release
gnutls_handshake() failed: Error in the pull function.
E: The repository ‘https://artifacts.loraserver.io/packages/1.x/deb stable Release’ does not have a Release file.
I think that proxy / firewall is off.
wssq
May 30, 2018, 8:24am
#6
finally I installed component by downloading package and then installing.
