I have a doubt about AS_PUBLIC_SERVER in lora-app-server config.
Can you, briefly, explain what exactly is this used for?
The only reference I seem to find is that himself access to this, but I dont see how loraserver access to lora-app-server.
Application Server public host
When running LoRa App Server on a different host than LoRa Server, make sure to set the --as-public-host to the correct hostname:port on which LoRa Server can reach LoRa App Server. The port must be equal to the port as configured by the --bind / BIND configuration.
Yes, read that, but don’t really know how does it work. It is aTCP connection? Do I have to open that port in docker confighuration? Wich is its real utility?
I don’t seem to see anything releated to AS server in loraserver configuration.
I see 3 ports that don’t know really what they do.
When you connect to LoRa Server in LoRa App Server (by creating a network-server entity), LoRa App Server also creates a routing-profile in LoRa Server holding the value of AS_PUBLIC_SERVER.
When uplink data is received, LoRa Server will forward this data to AS_PUBLIC_SERVER. This port must be the same as the LoRa App Server --bind.
Example, you have two servers: as.example.com and ns.example.com. When you tell LoRa App Server (as.) to connect to LoRa Server (ns.) and you create a device. LoRa Server must on uplink be able to send this data to as.example.com. In this case this config value will have the value as.example.com:8001.
Have been reading the documentation and cannot find “–as-public-host” option anywhere.
