I’m trying to setup my LNS as multi regional, which for the most part seems to be working fine with AU915sb2 gateways on a au915 gw bridge and AS923 gateways on a second as923 gateway bridge.
However the as923 side only ever passes traffic via the 2 x join channels. I added the channel block in the region_as923.toml (trying to mimic the eu868 plan) when I do this it only ever passes traffic to the 2 x join channels and the first added channel.
the devices do seem to try an transmit on the block of assigned channels as devices assigned to report every 10 minutes only do so if they hit a lucky channel as chirpstack only seems to pick up 3 channels as legitimate and flags the others as illegitimate as far as I can tell. I have added my logs and current config toml if anyone can point out what i’m possibly doing incorrect i would appreciate it very much!
My logs show these errors.
2023-03-14T23:22:38.327098Z ERROR chirpstack::uplink: Deduplication error error=No channel found for frequency: 924000000, dr: 0
2023-03-14T23:23:38.324953Z ERROR chirpstack::uplink: Deduplication error error=No channel found for frequency: 924600000, dr: 0
2023-03-14T23:24:59.922259Z ERROR chirpstack::uplink: Deduplication error error=No channel found for frequency: 924400000, dr: 5
2023-03-14T23:25:32.392725Z ERROR chirpstack::uplink: Deduplication error error=No channel found for frequency: 924600000, dr: 5
2023-03-14T23:25:39.385229Z ERROR chirpstack::uplink: Deduplication error error=No channel found for frequency: 924400000, dr: 5
2023-03-14T23:25:46.374833Z ERROR chirpstack::uplink: Deduplication error error=No channel found for frequency: 924600000, dr: 5
2023-03-14T23:25:56.688539Z ERROR chirpstack::uplink: Deduplication error error=No channel found for frequency: 924400000, dr: 0
2023-03-14T23:25:56.865651Z ERROR chirpstack::uplink: Deduplication error error=No channel found for frequency: 924200000, dr: 5
2023-03-14T23:26:08.902399Z ERROR chirpstack::uplink: Deduplication error error=No channel found for frequency: 923800000, dr: 5
2023-03-14T23:26:15.371950Z ERROR chirpstack::uplink: Deduplication error error=No channel found for frequency: 924000000, dr: 5
2023-03-14T23:26:32.367121Z ERROR chirpstack::uplink: Deduplication error error=No channel found for frequency: 924400000, dr: 5
2023-03-14T23:26:37.888405Z ERROR chirpstack::uplink: Deduplication error error=No channel found for frequency: 924600000, dr: 5
2023-03-14T23:26:48.368786Z ERROR chirpstack::uplink: Deduplication error error=No channel found for frequency: 924200000, dr: 5
2023-03-14T23:26:53.367072Z ERROR chirpstack::uplink: Deduplication error error=No channel found for frequency: 924000000, dr: 5
2023-03-14T23:26:57.865032Z ERROR chirpstack::uplink: Deduplication error error=No channel found for frequency: 923800000, dr: 5
2023-03-14T23:27:01.888606Z ERROR chirpstack::uplink: Deduplication error error=No channel found for frequency: 924200000, dr: 5
2023-03-14T23:27:08.365381Z ERROR chirpstack::uplink: Deduplication error error=No channel found for frequency: 923800000, dr: 0
This is what my region_as923.toml currently looks like.
[[regions]]
# Name is an user-defined identifier for this region.
name="as923"
# Common-name refers to the common-name of this region as defined by
# the LoRa Alliance.
common_name="AS923"
# Gateway configuration.
[regions.gateway]
# Force gateways as private.
# If enabled, gateways can only be used by devices under the same tenant.
force_gws_private=false
[regions.gateway.backend]
# The enabled backend type.
enabled="mqtt"
# MQTT configuration.
# Event topic template.
event_topic="as923/gateway/+/event/+"
# Command topic template.
command_topic="as923/gateway/{{ gateway_id }}/command/{{ command }}"
server="tcp://$MQTT_BROKER_HOST:1883"
username="$MQTT_USER"
password="$MQTT_PASS"
# Quality of service level
# 0: at most once
# 1: at least once
# 2: exactly once
qos=0
# Clean session
clean_session=false
# Client ID
# broker. A client id must be no longer than 23 characters. If left blank,
# a random id will be generated by ChirpStack.
client_id="region_as923"
ca_cert=""
tls_cert=""
# TLS key file (optional)
tls_key=""
# Gateway channel configuration.
# Note: this configuration is only used in case the gateway is using the
# ChirpStack Concentratord daemon. In any other case, this configuration
# is ignored.
[[regions.gateway.channels]]
frequency=923200000
bandwidth=125000
modulation="LORA"
spreading_factors=[7, 8, 9, 10, 11, 12]
frequency=923400000
bandwidth=125000
modulation="LORA"
# Region specific network configuration.
[regions.network]
# surrounded gateways.
installation_margin=10
# RX window (Class-A).
# Set this to:
# 0: RX1 / RX2
# 1: RX1 only
# 2: RX2 only
rx_window=0
# RX1 delay (1 - 15 seconds).
rx1_delay=1
# RX1 data-rate offset
rx1_dr_offset=0
# RX2 data-rate
rx2_dr=2
# RX2 frequency (Hz)
rx2_frequency=923200000
rx2_prefer_on_rx1_dr_lt=0
# Prefer RX2 on link budget.
# Downlink TX Power (dBm)
# be used.
downlink_tx_power=-1
# ADR is disabled.
adr_disabled=false
# Minimum data-rate.
min_dr=0
# Maximum data-rate.
max_dr=5
# Rejoin-request configuration (LoRaWAN 1.1)
[regions.network.rejoin_request]
# Request devices to periodically send rejoin-requests.
enabled=false
# The device must send a rejoin-request type 0 at least every 2^(max_count_n + 4)
# uplink messages. Valid values are 0 to 15.
max_count_n=0
# The device must send a rejoin-request type 0 at least every 2^(max_time_n + 10)
# seconds. Valid values are 0 to 15.
# 0 = roughly 17 minutes
# 15 = about 1 year
max_time_n=0
# Class-B configuration.
[regions.network.class_b]
# Ping-slot data-rate.
ping_slot_dr=3
# Ping-slot frequency (Hz)
# set this to 0 to use the default frequency plan for the configured region
ping_slot_frequency=0
# Below is the common set of extra channels. Please make sure that these
# channels are also supported by the gateways.
[[regions.network.extra_channels]]
frequency=923600000
min_dr=0
max_dr=5
frequency=923800000
min_dr=0
max_dr=5
frequency=924000000
min_dr=0
max_dr=5
frequency=924200000
min_dr=0
max_dr=5
frequency=924400000
min_dr=0
max_dr=5
frequency=924600000
min_dr=0
max_dr=5
