Auth error with code 16
Hi, Ihave generated an api token (in the swagger ui) and put Bearer in front of it. i then authenticate myself and try to list my tenants using the rest api. But I keep getting the error unathorized with code 16.
https://console.helium-iot.xyz/api/tenants?limit=1&offset=0
==> 401
{ “code”: 16, “message”: “”, “details”: }
When I check the token in jwt.io, I get the message that the signature is not valid
What am I doing wrong?
Thanks for help!
Hello, did you find your solution ? I have exactly the same problem
