I started using a free istante Ec2 on AWS under ubuntu. When I click on the firefox web browser , the istance freeze and the only think i can do is to stop and restart the istance. Free plan has only 1GB ram. Do You know if I change ec2 plan ( 2 GB or 4 GB) I could solve opening the web browser and finally run chirpstak application server?
When app and network server are running both on the same network where is the gateway, my UI shows Gateway running in last seen.
When app and network server are running both on an external cloud gateway is not seen.
Here are the setup:
Thank you sagarpatel, you saved me a lot of time.
I’ve found the issue with port 1700.
The instance was not linked to the right security group and port 1700 was not setup.
