Hey Everyone,
I am trying to add a gateway bridge to my server so I can send basic station from my gateway to it. I’ve only ever used a gateway bridge on the gateway using UDP packet forwarder → GW Bridge → MQTT Broker and am used to being able to subscribe to the MQTT Broker to view the messages for debugging.
In this setup using basic station, when I try to subscribe to the MQTT Broker the messages are unreadable:
$ mosquitto_sub -v -h 192.168.0.7 -p 1883 -t '#'
us915_1/gateway/00800000a000e250/state/conn 00800000a000e250
us915_1/gateway/00800000a000e250/event/up
@{?_:U?4?ʣ?`^???~P~?2??
??(*Y
00800000a000e250????
د??"
???د??0?????????=`?j?J?
@b ??]U??)?F-?J? ʚ|q?w?۾?
?(*Y
??????0?????????=??j??]P?
Yet it seems Chirpstack can still handle these messages as occasionally it seems to decode a message from the gateway bridge:
@_H??Bk??3?D\?L???ׯ
??(*Y
00800000a000e250???
???????0?????????=Aj?h?.?
application/44e81855-d8ba-46c2-9e79-751913962e0f/device/7894e80000027a0a/event/up
{"deduplicationId":"a4cb0214-0927-43bf-b453-12df0ef6f7e1","time":"2024-04-04T15:10:44.963786+00:00","deviceInfo":
{"tenantId":"52f14cd4-c6f1-4fbd-8f87-4025e1d49242","tenantName":"ChirpStack","applicationId":"44e81855-d8ba-46c2-9e79-751913962e0f","applicationName":"Kanata Monitoring","deviceProfileId":"6c94d1f8-6bbb-42af-b877-253ecc501987","deviceProfileName":"rbs305-ath","deviceName":"ATH 1","devEui":"7894e80000027a0a","deviceClassEnabled":"CLASS_A","tags":{}},
"devAddr":"01d5485f","adr":true,"dr":3,"fCnt":3,"fPort":2,"confirmed":false,"data":"FA0AFJATgA==",
"object":{"Protocol":1.0,"ATH":{"Event":"Periodic Report","Temperature":20.9,"Humidity":19.8},"Type":"ATH","Counter":4.0},"rxInfo":
[{"gatewayId":"00800000a000e250","uplinkId":1102833320,"gwTime":"2024-04-04T15:10:44.963786+00:00","nsTime":"2024-04-04T15:10:45.407236919+00:00","timeSinceGpsEpoch":"1396278662.963786s","rssi":-66,"snr":9.25,"location":
{"latitude":45.34017,"longitude":-75.8989},"context":"AAAAAAAAAAAA5wAAAmiaLg==","metadata":
{"region_config_id":"us915_1","region_common_name":"US915"},"crcStatus":"CRC_OK"}],"txInfo":{"frequency":905300000,"modulation":{"lora":
{"bandwidth":125000,"spreadingFactor":7,"codeRate":"CR_4_5"}}}}
Is this expected behaviour? Are the MQTT messages still in basic station when they reach the MQTT Broker?
It seems like things are working normally through the UI so I was just wondering if this is something I should be worried about or not.
