No uplink arrives after ADR - This does not happen when max ADR is set to 3
The sensor is able to join and send a first uplink but not after DR is set to 4.
The uplink message is verified to have been sent by the sensor and can be seen by the lora_pkt_fwd but not by station.
NOTE: This issue occurs on station → chirpstack-gateway-bridge.
using lora_pkt_fwd and a gateway-hosted chirpstack-gateway-bridge does not have this issue.
station init log
2021-08-05 03:37:29.501 [SYS:INFO] Process /usr/sbin/reset_sx1301 (pid=10923) completed 2021-08-05 03:37:29.501 [RAL:INFO] Lora gateway library version: Version: 5.0.1; 2021-08-05 03:37:29.518 [RAL:VERB] Connecting to device: /dev/spidev1.0 2021-08-05 03:37:29.518 [RAL:DEBU] SX130x txlut table (0 entries) 2021-08-05 03:37:29.518 [RAL:VERB] SX1301 rxrfchain 0: enable=1 freq=902.7MHz rssi_offset=-166.000000 type=2 tx_enable=1 tx_notch_freq=0 2021-08-05 03:37:29.518 [RAL:VERB] SX1301 rxrfchain 1: enable=1 freq=903.7MHz rssi_offset=-166.000000 type=2 tx_enable=0 tx_notch_freq=0 2021-08-05 03:37:29.519 [RAL:VERB] SX1301 ifchain 0: enable=1 rf_chain=0 freq=-400000 bandwidth=0 datarate=0 sync_word=0/0 2021-08-05 03:37:29.519 [RAL:VERB] SX1301 ifchain 1: enable=1 rf_chain=0 freq=-200000 bandwidth=0 datarate=0 sync_word=0/0 2021-08-05 03:37:29.519 [RAL:VERB] SX1301 ifchain 2: enable=1 rf_chain=0 freq=0 bandwidth=0 datarate=0 sync_word=0/0 2021-08-05 03:37:29.519 [RAL:VERB] SX1301 ifchain 3: enable=1 rf_chain=0 freq=200000 bandwidth=0 datarate=0 sync_word=0/0 2021-08-05 03:37:29.519 [RAL:VERB] SX1301 ifchain 4: enable=1 rf_chain=0 freq=300000 bandwidth=0 datarate=0 sync_word=0/0 2021-08-05 03:37:29.519 [RAL:VERB] SX1301 ifchain 5: enable=1 rf_chain=0 freq=400000 bandwidth=0 datarate=0 sync_word=0/0 2021-08-05 03:37:29.519 [RAL:VERB] SX1301 ifchain 6: enable=1 rf_chain=1 freq=-400000 bandwidth=0 datarate=0 sync_word=0/0 2021-08-05 03:37:29.519 [RAL:VERB] SX1301 ifchain 7: enable=1 rf_chain=1 freq=-200000 bandwidth=0 datarate=0 sync_word=0/0 2021-08-05 03:37:29.519 [RAL:VERB] SX1301 ifchain 8: enable=1 rf_chain=0 freq=300000 bandwidth=1 datarate=4 sync_word=0/0 2021-08-05 03:37:29.520 [RAL:VERB] SX1301 ifchain 9: enable=0 rf_chain=0 freq=0 bandwidth=0 datarate=0 sync_word=0/0 2021-08-05 03:37:29.520 [RAL:VERB] SX130x LBT not enabled 2021-08-05 03:37:29.520 [RAL:VERB] Station device: /dev/spidev1.0 (PPS capture disabled) 2021-08-05 03:37:32.879 [RAL:VERB] Concentrator started (3s357ms) 2021-08-05 03:37:32.879 [S2E:INFO] Configuring for region: US902 -- 902.0MHz..928.0MHz 2021-08-05 03:37:32.879 [S2E:VERB] DR0 SF10/BW125 2021-08-05 03:37:32.879 [S2E:VERB] DR1 SF9/BW125 2021-08-05 03:37:32.880 [S2E:VERB] DR2 SF8/BW125 2021-08-05 03:37:32.880 [S2E:VERB] DR3 SF7/BW125 2021-08-05 03:37:32.880 [S2E:VERB] DR4 SF8/BW500 2021-08-05 03:37:32.880 [S2E:VERB] DR5 undefined 2021-08-05 03:37:32.880 [S2E:VERB] DR6 undefined 2021-08-05 03:37:32.880 [S2E:VERB] DR7 undefined 2021-08-05 03:37:32.880 [S2E:VERB] DR8 SF12/BW500 (DN only) 2021-08-05 03:37:32.880 [S2E:VERB] DR9 SF11/BW500 (DN only) 2021-08-05 03:37:32.880 [S2E:VERB] DR10 SF10/BW500 (DN only) 2021-08-05 03:37:32.880 [S2E:VERB] DR11 SF9/BW500 (DN only) 2021-08-05 03:37:32.880 [S2E:VERB] DR12 SF8/BW500 2021-08-05 03:37:32.880 [S2E:VERB] DR13 SF7/BW500 (DN only) 2021-08-05 03:37:32.880 [S2E:VERB] DR14 undefined 2021-08-05 03:37:32.880 [S2E:VERB] DR15 undefined 2021-08-05 03:37:32.881 [S2E:VERB] TX power: 30.0 dBm EIRP 2021-08-05 03:37:32.881 [S2E:VERB] JoinEui list: 0 entries 2021-08-05 03:37:32.881 [S2E:VERB] NetID filter: FFFFFFFF-FFFFFFFF-FFFFFFFF-FFFFFFFF 2021-08-05 03:37:32.881 [S2E:VERB] Dev/test settings: nocca=0 nodc=0 nodwell=0
Chirpstack gateway bridge station config
[backend] # Backend type. type="basic_station" [backend.basic_station] bind="0.0.0.0:3001" tls_cert="/etc/chirpstack-gateway-bridge/ChirpstackGatewayBridge.pem" tls_key="/etc/chirpstack-gateway-bridge/ChirpstackGatewayBridge.pem" ca_cert="/etc/chirpstack-gateway-bridge/ChirpstackCA.crt" # Ping interval. ping_interval="2m0s" # This interval must be greater than the configured ping interval. read_timeout="2m5s" # Write timeout. write_timeout="3s" region="US915" frequency_min=902000000 frequency_max=928000000 # Concentrator configuration. [backend.basic_station.concentrators] # Multi-SF channel configuration. [backend.basic_station.concentrators.multi_sf] # Frequencies (Hz). frequencies=[ 902300000, 902500000, 902700000, 902900000, 903000000, 903100000, 903300000, 903500000, # 903700000, ] # LoRa STD channel. [backend.basic_station.concentrators.lora_std] # Frequency (Hz). frequency=903000000 # Bandwidth (Hz). bandwidth=500000 # Spreading factor. spreading_factor=8 # [backend.basic_station.concentrators.fsk] #frequency=868800000
Network server uplink channels
enabled_uplink_channels=[0, 1, 2, 3, 4, 5, 6, 7, 64] // I’ve also tried and empty array but same issue
MAX ADR 3 frame log using basic station (had to pastebin it since it’s pretty long)
MAX ADR 4 frame logs using basic station
[ { "txInfo": { "frequency": 923900000, "power": 20, "modulation": "LORA", "loRaModulationInfo": { "bandwidth": 500, "spreadingFactor": 10, "codeRate": "4/5", "polarizationInversion": true }, "board": 0, "antenna": 0, "timing": "DELAY", "delayTimingInfo": { "delay": "1s" }, "context": "AAAAAAAAAAAAKwAAEcdChA==" }, "phyPayload": { "mhdr": { "mType": "UnconfirmedDataDown", "major": "LoRaWANR1" }, "macPayload": { "fhdr": { "devAddr": "0106e24b", "fCtrl": { "adr": true, "adrAckReq": false, "ack": false, "fPending": false, "classB": false }, "fCnt": 0, "fOpts": null }, "fPort": 0, "frmPayload": [ { "cid": "DeviceTimeReq", "payload": { "timeSinceGPSEpoch": 1312170655070312400 } }, { "cid": "LinkADRReq", "payload": { "dataRate": 0, "txPower": 0, "chMask": [ true, false, false, false, false, false, false, false, false, false, false, false, false, false, false, false ], "redundancy": { "chMaskCntl": 7, "nbRep": 0 } } }, { "cid": "LinkADRReq", "payload": { "dataRate": 4, "txPower": 0, "chMask": [ true, true, true, true, true, true, true, true, false, false, false, false, false, false, false, false ], "redundancy": { "chMaskCntl": 0, "nbRep": 1 } } } ] }, "mic": "41fd4ba6" } }, { "rxInfo": [ { "gatewayID": "qEBBHaT0QVM=", "time": null, "timeSinceGPSEpoch": null, "rssi": -103, "loRaSNR": 9.25, "channel": 0, "rfChain": 0, "board": 0, "antenna": 0, "location": { "latitude": 0, "longitude": 0, "altitude": 0, "source": "UNKNOWN", "accuracy": 0 }, "fineTimestampType": "NONE", "context": "AAAAAAAAAAAAKwAAEcdChA==", "uplinkID": "RMrRE682SxeVT+c7SFZrRw==", "crcStatus": "CRC_OK" } ], "txInfo": { "frequency": 902500000, "modulation": "LORA", "loRaModulationInfo": { "bandwidth": 125, "spreadingFactor": 10, "codeRate": "4/5", "polarizationInversion": false } }, "phyPayload": { "mhdr": { "mType": "UnconfirmedDataUp", "major": "LoRaWANR1" }, "macPayload": { "fhdr": { "devAddr": "0106e24b", "fCtrl": { "adr": true, "adrAckReq": false, "ack": false, "fPending": false, "classB": false }, "fCnt": 0, "fOpts": [ { "cid": "DeviceTimeReq", "payload": null } ] }, "fPort": 2, "frmPayload": [ { "bytes": "qg==" } ] }, "mic": "050ec0d8" } }, { "txInfo": { "frequency": 923300000, "power": 20, "modulation": "LORA", "loRaModulationInfo": { "bandwidth": 500, "spreadingFactor": 10, "codeRate": "4/5", "polarizationInversion": true }, "board": 0, "antenna": 0, "timing": "DELAY", "delayTimingInfo": { "delay": "5s" }, "context": "AAAAAAAAAAAAKwAAEXP3DA==" }, "phyPayload": { "mhdr": { "mType": "JoinAccept", "major": "LoRaWANR1" }, "macPayload": { "bytes": "0qFRO/OG1jrfCFmQak9wbUXqhmH+s3pDXXA+kQ==" }, "mic": "0b06b72a" } }, { "rxInfo": [ { "gatewayID": "qEBBHaT0QVM=", "time": null, "timeSinceGPSEpoch": null, "rssi": -101, "loRaSNR": 8.25, "channel": 0, "rfChain": 0, "board": 0, "antenna": 0, "location": { "latitude": 0, "longitude": 0, "altitude": 0, "source": "UNKNOWN", "accuracy": 0 }, "fineTimestampType": "NONE", "context": "AAAAAAAAAAAAKwAAEXP3DA==", "uplinkID": "sRYHg3sPSFKnQkBOsz+HDw==", "crcStatus": "CRC_OK" } ], "txInfo": { "frequency": 902300000, "modulation": "LORA", "loRaModulationInfo": { "bandwidth": 125, "spreadingFactor": 10, "codeRate": "4/5", "polarizationInversion": false } }, "phyPayload": { "mhdr": { "mType": "JoinRequest", "major": "LoRaWANR1" }, "macPayload": { "joinEUI": "a000000000000100", "devEUI": "a84041658182b7fb", "devNonce": 9270 }, "mic": "7009a25a" } } ]
The uplinks not showing in the application can be seen with the lora_pkt_fwd (dev addr 0106E24B)
REPORT~ ################## Report at: 2021-08-05 03:52:16 UTC ################## REPORT~ ### [UPSTREAM] ### REPORT~ # RF packets received by concentrator: 0 REPORT~ # CRC_OK: 0.00%, CRC_FAIL: 0.00%, NO_CRC: 0.00% REPORT~ # RF packets forwarded: 0 (0 bytes) REPORT~ # PUSH_DATA datagrams sent: 0 (0 bytes) REPORT~ # PUSH_DATA acknowledged: 0.00% REPORT~ ### [DOWNSTREAM] ### REPORT~ # PULL_DATA sent: 0 (0.00% acknowledged) WARNING~ [down] relink recv error sockup(3),sockdown(4) INFO~ sockfd=4 REPORT~ # PULL_RESP(onse) datagrams received: 0 (0 bytes) REPORT~ # RF packets sent to concentrator: 0 (0 bytes) REPORT~ # TX errors: 0 REPORT~ # BEACON queued: 0 REPORT~ # BEACON sent so far: 0 REPORT~ # BEACON rejected: 0 REPORT~ ### [PPS] ### REPORT~ # SX1301 time (PPS): 2879633 INFO: [jit] queue is empty INFO~ ### [GPS] ### INFO~ # GPS *FAKE* coordinates: latitude 22.700000, longitude 114.240000, altitude 450 m INFO~ ##### END ##### RXTX~ {"stat":{"time":"2021-08-05 03:52:16 UTC","lati":22.700000,"long":114.240000,"alti":450,"rxnb":0,"rxok":0,"rxfw":0,"ackr":0.0,"dwnb":0,"txnb":0}} debug2: client_check_window_change: changed debug2: channel 0: request window-change confirm 0 lgw_receive:1154: FIFO content: 1 10 0 5 18 lgw_receive:1173: [8 16] Note: LoRa packet PKT_FWD~ DATA_UNCONF_UP-> {"DevAddr": "0106E24B", "FCtrl": ["ADR": 1, "ADRACKReq": 0, "ACK": 0, "RFU" : "RFU", "FOptsLen": 0], "FCnt": 5, "FPort": 2, "MIC": "CACD0FE9"} RXTX~ {"rxpk":[{"tmst":23148464,"time":"2021-08-05T03:52:36.313126Z","chan":8,"rfch":0,"freq":903.000000,"stat":1,"modu":"LORA","datr":"SF8BW500","codr":"4/5","lsnr":8.2,"rssi":-108,"size":24,"data":"QEviBgGABQACxjJy1CDdfsuVsWDpD83K"}]} lgw_receive:1154: FIFO content: 1 38 0 7 12 lgw_receive:1173: [0 17] Note: LoRa packet PKT_FWD~ DATA_CONF_UP-> {"DevAddr": "BFA9F36D", "FCtrl": ["ADR": 1, "ADRACKReq": 1, "ACK": 1, "RFU" : "RFU", "FOptsLen": 6], "FCnt": 39630, "FPort": 0, "MIC": "9E21B2E4"} WARNING~ [down] relink recv error sockup(3),sockdown(4) INFO~ sockfd=4
lora_pkt_fwd init log
INFO~ Configuring TX LUT with 16 indexes
INFO~ radio 0 enabled (type SX1257), center frequency 902700000, RSSI offset -166.000000, tx enabled 1, tx_notch_freq 0
lgw_rxrf_setconf:473: WARNING: NOT A VALID TX NOTCH FILTER FREQUENCY [126000…250000]Hz
lgw_rxrf_setconf:485: Note: rf_chain 0 configuration; en:1 freq:902700000 rssi_offset:-166.000000 radio_type:2 tx_enable:1 tx_notch_freq:0
INFO~ radio 1 enabled (type SX1257), center frequency 903400000, RSSI offset -166.000000, tx enabled 0, tx_notch_freq 0
lgw_rxrf_setconf:485: Note: rf_chain 1 configuration; en:1 freq:903400000 rssi_offset:-166.000000 radio_type:2 tx_enable:0 tx_notch_freq:0
INFO~ Lora multi-SF channel 0> radio 0, IF -400000 Hz, 125 kHz bw, SF 7 to 12
lgw_rxif_setconf:604: Note: LoRa ‘multi’ if_chain 0 configuration; en:1 freq:-400000 SF_mask:0x7e
INFO~ Lora multi-SF channel 1> radio 0, IF -200000 Hz, 125 kHz bw, SF 7 to 12
lgw_rxif_setconf:604: Note: LoRa ‘multi’ if_chain 1 configuration; en:1 freq:-200000 SF_mask:0x7e
INFO~ Lora multi-SF channel 2> radio 0, IF 0 Hz, 125 kHz bw, SF 7 to 12
lgw_rxif_setconf:604: Note: LoRa ‘multi’ if_chain 2 configuration; en:1 freq:0 SF_mask:0x7e
INFO~ Lora multi-SF channel 3> radio 0, IF 200000 Hz, 125 kHz bw, SF 7 to 12
lgw_rxif_setconf:604: Note: LoRa ‘multi’ if_chain 3 configuration; en:1 freq:200000 SF_mask:0x7e
INFO~ Lora multi-SF channel 4> radio 1, IF -300000 Hz, 125 kHz bw, SF 7 to 12
lgw_rxif_setconf:604: Note: LoRa ‘multi’ if_chain 4 configuration; en:1 freq:-300000 SF_mask:0x7e
INFO~ Lora multi-SF channel 5> radio 1, IF -100000 Hz, 125 kHz bw, SF 7 to 12
lgw_rxif_setconf:604: Note: LoRa ‘multi’ if_chain 5 configuration; en:1 freq:-100000 SF_mask:0x7e
INFO~ Lora multi-SF channel 6> radio 1, IF 100000 Hz, 125 kHz bw, SF 7 to 12
lgw_rxif_setconf:604: Note: LoRa ‘multi’ if_chain 6 configuration; en:1 freq:100000 SF_mask:0x7e
INFO~ Lora multi-SF channel 7> radio 1, IF 300000 Hz, 125 kHz bw, SF 7 to 12
lgw_rxif_setconf:604: Note: LoRa ‘multi’ if_chain 7 configuration; en:1 freq:300000 SF_mask:0x7e
INFO~ Lora std channel> radio 0, IF 300000 Hz, 500000 Hz bw, SF 8
lgw_rxif_setconf:578: Note: LoRa ‘std’ if_chain 8 configuration; en:1 freq:300000 bw:1 dr:4
INFO~ FSK channel 8 disabled
lgw_rxif_setconf:512: Note: if_chain 9 disabled
