Hi ChirpStack community,
I’m trying to retrieve the most recent metrics (temperature, humidity, battery) for a specific device by its EUI via API. While I see time-range endpoints like:
/api/devices/{devEui}/metrics?start=...&end=...
I’m looking for a simpler way to get just the last reported values without calculating time windows.
What I’ve Tried:
/framesendpoint → Returns “Not Found” (code 5)/metricswithout timestamps → “start is None” error (code 13)- Setting arbitrary old
startdate → Works but feels hacky
Question:
Is there a built-in endpoint to fetch only the most recent metrics? If not, what’s the recommended approach?
Current Workaround:
curl -X GET \
"http://server:8090/api/devices/DEV_EUI/metrics?limit=1&start=2020-01-01T00:00:00Z" \
-H "Grpc-Metadata-Authorization: Bearer API_KEY"
