I have a gateway which doesn’t have a gps lock at the moment. As a result it transmit 0/0 as current coordinate. Is there any way to use the configured position instead of the “real” data? Unfortunately turning off the meta data is not an option, as I’m interested in the rf statistics.
Thanks
You may set the fake_gps
option to true and then provide hardcoded values for ref_latitude
, ref_longitude
and ref_altitude
at the packet forwarder’s configuration (global_conf.json
or local_conf.json
The manufacturer said there is no option in the config file, but I’ll give it a try.
Thank you for the suggestion
Just out of curiosity, which vendor (or what gateway) would that be?
Please note that in the latest LoRa Gateway Bridge version, lat / long / alt = 0 will be ignored
