It appears my bridge is no longer connecting to the MQTT server, and I don’t understand why. Everything is running in a container and has been fine for ages. As of 2024-01-22T13:33:22, it appears things stopped working. I am not positive if I did an update at that time, as it would be about 8:30am in the morning, and that would be somewhat unusual, although I honestly can’t remember that far back ![]()
As part of the effort to resolve this issue, I did do a docker-compose pull to update everything, and it made no difference. Here’s the relevant section from the the docker logs loraserver-docker_chirpstack-gateway-bridge_1 output.
time="2024-01-22T13:33:29.889372382Z" level=info msg="integration/mqtt: publishing event" downlink_id=53bf7c1d-3eff-481d-ada2-0fa24d3dfaf8 event=ack qos=0 topic=gateway/e45f01fffe17c7bc/event/ack
time="2024-01-22T13:33:39.826852443Z" level=info msg="integration/mqtt: publishing event" event=stats qos=0 stats_id=dcd51d2e-a019-4555-a40f-e4b24dfad1db topic=gateway/e45f01fffe17c7bc/event/stats
time="2024-01-22T13:34:09.83452081Z" level=info msg="integration/mqtt: publishing event" event=stats qos=0 stats_id=be705226-71cc-479a-bab9-5c8eac6a03c3 topic=gateway/e45f01fffe17c7bc/event/stats
time="2024-01-22T13:34:22.178786317Z" level=error msg="[client] Connect comms goroutine - error triggered EOF" module=mqtt
time="2024-01-22T13:34:22.180133378Z" level=info msg="signal received" signal=terminated
time="2024-01-22T13:34:22.231048364Z" level=warning msg="shutting down server"
time="2024-01-22T13:34:22.23168051Z" level=error msg="mqtt: connection error" error=EOF
time="2024-01-22T13:34:22.596003786Z" level=info msg="integration/mqtt: publishing state" gateway_id=e45f01fffe17c7bc qos=0 state=conn topic=gateway/e45f01fffe17c7bc/state/conn
time="2024-01-22T13:34:22.755929697Z" level=error msg="[client] dial tcp 192.168.32.7:11883: connect: connection refused" module=mqtt
time="2024-01-22T13:34:22.789131597Z" level=warning msg="[client] failed to connect to broker, trying next" module=mqtt
time="2024-01-22T13:35:57.761993149Z" level=info msg="starting ChirpStack Gateway Bridge" docs="https://www.chirpstack.io/gateway-bridge/" version=
time="2024-01-22T13:35:57.762085311Z" level=info msg="backend/semtechudp: starting gateway udp listener" addr="0.0.0.0:11700"
time="2024-01-22T13:36:01.554256507Z" level=error msg="[client] dial tcp 192.168.32.8:11883: connect: no route to host" module=mqtt
time="2024-01-22T13:36:01.554316892Z" level=warning msg="[client] failed to connect to broker, trying next" module=mqtt
time="2024-01-22T13:36:01.554349225Z" level=error msg="[client] Failed to connect to a broker" module=mqtt
time="2024-01-22T13:36:01.554391564Z" level=error msg="integration/mqtt: connection error" error="network Error : dial tcp 192.168.32.8:11883: connect: no route to host"
time="2024-01-22T13:36:03.555722517Z" level=warning msg="[client] status is already disconnected" module=mqtt
time="2024-01-22T13:36:04.626330424Z" level=error msg="[client] dial tcp 192.168.32.8:11883: connect: no route to host" module=mqtt
time="2024-01-22T13:36:04.626398743Z" level=warning msg="[client] failed to connect to broker, trying next" module=mqtt
time="2024-01-22T13:36:04.626437497Z" level=error msg="[client] Failed to connect to a broker" module=mqtt
time="2024-01-22T13:36:04.626494216Z" level=error msg="integration/mqtt: connection error" error="network Error : dial tcp 192.168.32.8:11883: connect: no route to host"
When I do a docker-compose ps, I see the following:
Name Command State Ports
loraserver-docker_chirpstack-application-server_1 /usr/bin/chirpstack-applic ... Up 0.0.0.0:18001->18001/tcp,:::18001->18001/tcp, 0.0.0.0:18080->18080/tcp,:::18080->18080/tcp
loraserver-docker_chirpstack-gateway-bridge_1 /usr/bin/chirpstack-gatewa ... Up 0.0.0.0:11700->11700/udp,:::11700->11700/udp
loraserver-docker_chirpstack-geolocation-server_1 ./chirpstack-geolocation-s ... Up 0.0.0.0:18005->18005/tcp,:::18005->18005/tcp
loraserver-docker_chirpstack-network-server_1 /usr/bin/chirpstack-networ ... Up 0.0.0.0:18003->18003/tcp,:::18003->18003/tcp
loraserver-docker_mosquitto_1 /docker-entrypoint.sh /usr ... Up 0.0.0.0:11883->11883/tcp,:::11883->11883/tcp, 1883/tcp
loraserver-docker_postgresql_1 docker-entrypoint.sh postgres Up 5432/tcp
loraserver-docker_redis_1 docker-entrypoint.sh redis ... Up 6379/tcp
The mosquitto logs seems to think a client is connecting.
1706026256: mosquitto version 2.0.18 starting
1706026256: Config loaded from /mosquitto/config/mosquitto.conf.
1706026256: Opening ipv4 listen socket on port 11883.
1706026256: Opening ipv6 listen socket on port 11883.
1706026256: mosquitto version 2.0.18 running
1706026257: New connection from 192.168.32.2:56064 on port 11883.
1706026257: New client connected from 192.168.32.2:56064 as auto-3B9FDABB-D0FE-A0C0-E802-616DD1D7610D (p2, c1, k30).
1706026258: New connection from 192.168.32.5:49720 on port 11883.
1706026258: New client connected from 192.168.32.5:49720 as auto-A2D8AED2-1EAA-24A1-7990-0A8939BD69E0 (p2, c1, k30).
1706026264: New connection from 172.16.1.25:56662 on port 11883.
1706026264: New client connected from 172.16.1.25:56662 as nodered_5d624415f6ed64a6 (p2, c1, k60).
Why would this stop working? One thing I noticed that when the bridge is starting up that the version is blank. Where else can I check what version of Chirpstack is running? It doesn’t appear to be anywhere in the web interface.
Any help would be greatly appreciated.
