We want to integrate the mini hub gateway from browan “https://www.browan.com/product/minihub/detail” with our chirpstack server, since there is not documented this gateway on the gateway bridge instalation section, is any other way to integrate it? Thanks !!!
Since it is likely the same Gemtek gateway that is branded by many companies, you may have luck starting here:
https://www.gemteks.com/en/products/lora-iot/gateway
Then again, it could be a completely different firmware, who knows.
