Hii @brocaar
Setup:
I have installed 2 Network Server on IN865
First NS is on Default Configuration
Another NS is RX2DR = 5
we have installed 1 Application Server and Added Both NS.
We have installed 1 gateway in 1st NS (Default Configuration)
we have added one device on Another NS is RX2DR=5 and created one Multicast group for this device.
Issue:
When I send multicast downlink using SWAGGER API it will return below error.
enqueue multicast-group queue-item error: enqueue multicast-queue item error: rpc error: code = NotFound desc = object does not exist (code: 13)
I have debugged issue.
NS server return error due to GW foreign key configured in multicast_queue
table
if ts.IsZero() {
ts = time.Now()
for _, gatewayID := range gatewayIDs {
ts = ts.Add(multicastGatewayDelay)
qi.GatewayID = gatewayID
qi.ScheduleAt = ts
if err = storage.CreateMulticastQueueItem(ctx, db, &qi); err != nil {
return errors.Wrap(err, "create multicast queue-item error")
// for each gateway the use the next ping-slot
if mg.GroupType == storage.MulticastGroupB {
var pingSlotNb int
if mg.PingSlotPeriod != 0 {
pingSlotNb = (1 << 12) / mg.PingSlotPeriod
Can you please give us any solution?
But according to your above description, NS2 (RX2DR=5) has no gateway configured. I don’t know about the rest of your configuration, but this might be your issue.
If this is a bug, then please note that the forum is not a good place for reporting bugs. Use GitHub issues instead (and even better, provide a pull-request with the fix ) .
I’ll close this topic then.
