this is error msg
[nix-shell:~/chirpstack-master/chirpstack]$ make debug-amd64
cross build --target x86_64-unknown-linux-musl
[+] Building 3.7s (6/6) FINISHED
=> [internal] load .dockerignore 0.0s
=> => transferring context: 148B 0.0s
=> [internal] load build definition from Dockerfile.x86_64-unknown-linux-musl 0.0s
=> => transferring dockerfile: 224B 0.0s
=> [internal] load metadata for ghcr.io/cross-rs/x86_64-unknown-linux-musl:latest 3.5s
=> [1/2] FROM ghcr.io/cross-rs/x86_64-unknown-linux-musl:latest@sha256:77db671d8356a64ae72a3e1415e63f547f26d374fbe3c4762c1cd36c7eac7b99 0.0s
=> CACHED [2/2] RUN apt-get update && apt-get --assume-yes install protobuf-compiler libprotobuf-dev 0.0s
=> exporting to image 0.0s
=> => exporting layers 0.0s
=> => writing image sha256:48662e12cc0f3759dfd07b419ae4aabf544f4b405b4fb20513fa1a48dd2a60bb 0.0s
=> => naming to docker.io/library/cross-custom-chirpstack-master:x86_64-unknown-linux-musl-1fb72 0.0s
Compiling chirpstack v4.7.0-test.3 (/project/chirpstack)
error: #[derive(RustEmbed)] folder '/project/chirpstack/../ui/build' does not exist. cwd: '/project'
--> chirpstack/src/api/mod.rs:95:1
95 | / #[folder = "../ui/build"]
96 | | struct Asset;
| |_____________^
error[E0599]: no function or associated item named `get` found for struct `Asset` in the current scope
--> chirpstack/src/api/mod.rs:287:24
96 | struct Asset;
| ------------ function or associated item `get` not found for this struct
287 | let asset = Asset::get(path).ok_or_else(warp::reject::not_found)?;
| ^^^ function or associated item not found in `Asset`
= help: items from traits can only be used if the trait is implemented and in scope
= note: the following traits define an item `get`, perhaps you need to implement one of them:
candidate #1: `SliceIndex`
candidate #2: `diesel::row::Row`
candidate #3: `NamedRow`
candidate #4: `toml_edit::table::TableLike`
candidate #5: `MulticastGroupService`
candidate #6: `GatewayService`
candidate #7: `DeviceService`
candidate #8: `DeviceProfileTemplateService`
candidate #9: `DeviceProfileService`
candidate #10: `ApplicationService`
candidate #11: `TenantService`
candidate #12: `UserService`
candidate #13: `tonic::metadata::map::as_metadata_key::Sealed`
candidate #14: `prometheus_client::metrics::counter::Atomic`
candidate #15: `prometheus_client::metrics::gauge::Atomic`
candidate #16: `RustEmbed`
candidate #17: `StoresServerSessions`
candidate #18: `redis::Commands`
candidate #19: `AsyncCommands`
candidate #20: `crc16::CrcType`
candidate #21: `rdkafka::message::Headers`
For more information about this error, try `rustc --explain E0599`.
error: could not compile `chirpstack` (bin "chirpstack") due to 2 previous errors
make: *** [Makefile:6: debug-amd64] Error 101
[nix-shell:~/chirpstack-master/chirpstack]$ ls
Cargo.toml Makefile configuration debian diesel.toml migrations rpm src
