Hi
I am a newbie here, and in the first steps, I have encountered errors. I am not sure if here is the correct place to ask, but where else? Esp. as I could not find relevant results elsewhere .
The problem is an error in the building of icu_70:
The error log is:
Build Configuration:
BB_VERSION = “2.0.0”
BUILD_SYS = “x86_64-linux”
NATIVELSBSTRING = “debian-10”
TARGET_SYS = “arm-oe-linux-gnueabi”
MACHINE = “raspberrypi3”
DISTRO = “chirpstack-gateway-os”
DISTRO_VERSION = “4.1.1”
TUNE_FEATURES = “arm vfp cortexa7 neon vfpv4 thumb callconvention-hard”
TARGET_FPU = “hard”
meta
meta-swupdate
meta-clang
meta-raspberrypi
meta-networking
meta-filesystems
meta-python
meta-oe
meta = “:”
Initialising tasks: 100% |#######################################| Time: 0:00:03
Sstate summary: Wanted 1140 Local 0 Mirrors 0 Missed 1140 Current 439 (0% match, 27% complete)
NOTE: Executing Tasks
ERROR: icu-70.1-r0 do_compile: oe_runmake failed
ERROR: icu-70.1-r0 do_compile: ExecutionError(‘/build/tmp/raspberrypi3-glibc/work/cortexa7t2hf-neon-vfpv4-oe-linux-gnueabi/icu/70.1-r0/temp/run.do_compile.104’, 1, None, None)
ERROR: Logfile of failure stored in: /build/tmp/raspberrypi3-glibc/work/cortexa7t2hf-neon-vfpv4-oe-linux-gnueabi/icu/70.1-r0/temp/log.do_compile.104
Log data follows:
| DEBUG: Executing python function autotools_aclocals
| DEBUG: SITE files [‘endian-little’, ‘bit-32’, ‘arm-common’, ‘arm-32’, ‘common-linux’, ‘common-glibc’, ‘arm-linux’, ‘arm-linux-gnueabi’, ‘common’]
| DEBUG: Python function autotools_aclocals finished
| DEBUG: Executing shell function do_compile
| NOTE: make -j 8
| Note: rebuild with "make VERBOSE=1 " to show all compiler parameters.
| make[0]: Making all' in
stubdata’
| make[1]: Entering directory ‘/build/tmp/raspberrypi3-glibc/work/cortexa7t2hf-neon-vfpv4-oe-linux-gnueabi/icu/70.1-r0/build/stubdata’
| make[1]: Nothing to be done for ‘all’.
| make[1]: Leaving directory ‘/build/tmp/raspberrypi3-glibc/work/cortexa7t2hf-neon-vfpv4-oe-linux-gnueabi/icu/70.1-r0/build/stubdata’
common’
| make[1]: Entering directory ‘/build/tmp/raspberrypi3-glibc/work/cortexa7t2hf-neon-vfpv4-oe-linux-gnueabi/icu/70.1-r0/build/common’
| make[1]: Leaving directory ‘/build/tmp/raspberrypi3-glibc/work/cortexa7t2hf-neon-vfpv4-oe-linux-gnueabi/icu/70.1-r0/build/common’
i18n’
| make[1]: Entering directory ‘/build/tmp/raspberrypi3-glibc/work/cortexa7t2hf-neon-vfpv4-oe-linux-gnueabi/icu/70.1-r0/build/i18n’
| make[1]: Leaving directory ‘/build/tmp/raspberrypi3-glibc/work/cortexa7t2hf-neon-vfpv4-oe-linux-gnueabi/icu/70.1-r0/build/i18n’
io’
| make[1]: Entering directory ‘/build/tmp/raspberrypi3-glibc/work/cortexa7t2hf-neon-vfpv4-oe-linux-gnueabi/icu/70.1-r0/build/io’
| make[1]: Leaving directory ‘/build/tmp/raspberrypi3-glibc/work/cortexa7t2hf-neon-vfpv4-oe-linux-gnueabi/icu/70.1-r0/build/io’
tools’
| make[1]: Entering directory ‘/build/tmp/raspberrypi3-glibc/work/cortexa7t2hf-neon-vfpv4-oe-linux-gnueabi/icu/70.1-r0/build/tools’
| make[1]: Making all' in
toolutil’
| make[2]: Entering directory ‘/build/tmp/raspberrypi3-glibc/work/cortexa7t2hf-neon-vfpv4-oe-linux-gnueabi/icu/70.1-r0/build/tools/toolutil’
| make[2]: Nothing to be done for ‘all’.
| make[2]: Leaving directory ‘/build/tmp/raspberrypi3-glibc/work/cortexa7t2hf-neon-vfpv4-oe-linux-gnueabi/icu/70.1-r0/build/tools/toolutil’
ctestfw’
| make[2]: Entering directory ‘/build/tmp/raspberrypi3-glibc/work/cortexa7t2hf-neon-vfpv4-oe-linux-gnueabi/icu/70.1-r0/build/tools/ctestfw’
| make[2]: Leaving directory ‘/build/tmp/raspberrypi3-glibc/work/cortexa7t2hf-neon-vfpv4-oe-linux-gnueabi/icu/70.1-r0/build/tools/ctestfw’
makeconv’
| make[2]: Entering directory ‘/build/tmp/raspberrypi3-glibc/work/cortexa7t2hf-neon-vfpv4-oe-linux-gnueabi/icu/70.1-r0/build/tools/makeconv’
| arm-oe-linux-gnueabi-g++ -mthumb -mfpu=neon-vfpv4 -mfloat-abi=hard -mcpu=cortex-a7 --sysroot=/build/tmp/raspberrypi3-glibc/work/cortexa7t2hf-neon-vfpv4-oe-linux-gnueabi/icu/70.1-r0/recipe-sysroot -O2 -pipe -g -feliminate-unused-debug-types -fmacro-prefix-map=/build/tmp/raspberrypi3-glibc/work/cortexa7t2hf-neon-vfpv4-oe-linux-gnueabi/icu/70.1-r0=/usr/src/debug/icu/70.1-r0 -fdebug-prefix-map=/build/tmp/raspberrypi3-glibc/work/cortexa7t2hf-neon-vfpv4-oe-linux-gnueabi/icu/70.1-r0=/usr/src/debug/icu/70.1-r0 -fdebug-prefix-map=/build/tmp/raspberrypi3-glibc/work/cortexa7t2hf-neon-vfpv4-oe-linux-gnueabi/icu/70.1-r0/recipe-sysroot= -fdebug-prefix-map=/build/tmp/raspberrypi3-glibc/work/cortexa7t2hf-neon-vfpv4-oe-linux-gnueabi/icu/70.1-r0/recipe-sysroot-native= -fvisibility-inlines-hidden -W -Wall -pedantic -Wpointer-arith -Wwrite-strings -Wno-long-long -std=c++11 -Wl,-O1 -Wl,–hash-style=gnu -fmacro-prefix-map=/build/tmp/raspberrypi3-glibc/work/cortexa7t2hf-neon-vfpv4-oe-linux-gnueabi/icu/70.1-r0=/usr/src/debug/icu/70.1-r0 -fdebug-prefix-map=/build/tmp/raspberrypi3-glibc/work/cortexa7t2hf-neon-vfpv4-oe-linux-gnueabi/icu/70.1-r0=/usr/src/debug/icu/70.1-r0 -fdebug-prefix-map=/build/tmp/raspberrypi3-glibc/work/cortexa7t2hf-neon-vfpv4-oe-linux-gnueabi/icu/70.1-r0/recipe-sysroot= -fdebug-prefix-map=/build/tmp/raspberrypi3-glibc/work/cortexa7t2hf-neon-vfpv4-oe-linux-gnueabi/icu/70.1-r0/recipe-sysroot-native= -o …/…/bin/makeconv gencnvex.o genmbcs.o makeconv.o ucnvstat.o -L…/…/lib -licutu -L…/…/lib -licui18n -L…/…/lib -licuuc -L…/…/stubdata -licudata -lpthread -lm
| …arm-oe-linux-gnueabi/11.3.0/ld: …/…/lib/libicui18n.so: undefined reference to icu_70::Calendar::Calendar(UErrorCode&)' | ......arm-oe-linux-gnueabi/11.3.0/ld: ../../lib/libicui18n.so: undefined reference to
icu_70::CalendarAstronomer::getMoonTime(icu_70::CalendarAstronomer::MoonAge const&, signed char)’
| …arm-oe-linux-gnueabi/11.3.0/ld: …/…/lib/libicui18n.so: undefined reference to icu_70::Calendar::set(int, int, int)' | ......arm-oe-linux-gnueabi/11.3.0/ld: ../../lib/libicui18n.so: undefined reference to
icu_70::getCalendarTypeFromLocale(icu_70::Locale const&, char*, int, UErrorCode&)’
| …arm-oe-linux-gnueabi/11.3.0/ld: …/…/lib/libicui18n.so: undefined reference to icu_70::BreakTransliterator::BreakTransliterator(icu_70::UnicodeFilter*)' | ......arm-oe-linux-gnueabi/11.3.0/ld: ../../lib/libicui18n.so: undefined reference to
icu_70::pinField(UCalendarDateFields, UErrorCode&)’
| …arm-oe-linux-gnueabi/11.3.0/ld: …/…/lib/libicui18n.so: undefined reference to icu_70::Calendar::add(icu_70::Calendar::EDateFields, int, UErrorCode&)' | ......arm-oe-linux-gnueabi/11.3.0/ld: ../../lib/libicui18n.so: undefined reference to
icu_70::getMinimum(icu_70:
:EDateFields) const’
| …arm-oe-linux-gnueabi/11.3.0/ld: …/…/lib/libicui18n.so: undefined reference to icu_70::Calendar::getFieldResolutionTable() const' | ......arm-oe-linux-gnueabi/11.3.0/ld: ../../lib/libicui18n.so: undefined reference to
icu_70::newestStamp(UCalendarDateFields, UCalendarDateFields, int) const’
| …arm-oe-linux-gnueabi/11.3.0/ld: …/…/lib/libicui18n.so: undefined reference to icu_70::Calendar::setMinimalDaysInFirstWeek(unsigned char)' | ......arm-oe-linux-gnueabi/11.3.0/ld: ../../lib/libicui18n.so: undefined reference to
icu_70::setFirstDayOfWeek(UCalendarDaysOfWeek)’
| …arm-oe-linux-gnueabi/11.3.0/ld: …/…/lib/libicui18n.so: undefined reference to icu_70::Calendar::Calendar(icu_70::Calendar const&)' | ......arm-oe-linux-gnueabi/11.3.0/ld: ../../lib/libicui18n.so: undefined reference to
icu_70::handleGetYearLength(int) const’
| …arm-oe-linux-gnueabi/11.3.0/ld: …/…/lib/libicui18n.so: undefined reference to icu_70::Calendar::setSkippedWallTimeOption(UCalendarWallTimeOption)' | ......arm-oe-linux-gnueabi/11.3.0/ld: ../../lib/libicui18n.so: undefined reference to
icu_70::fieldDifference(double, UCalendarDateFields, UErrorCode&)’
| …arm-oe-linux-gnueabi/11.3.0/ld: …/…/lib/libicui18n.so: undefined reference to icu_70::Calendar::isLenient() const' | ......arm-oe-linux-gnueabi/11.3.0/ld: ../../lib/libicui18n.so: undefined reference to
icu_70::AnyTransliterator::registerIDs()’
| …arm-oe-linux-gnueabi/11.3.0/ld: …/…/lib/libicui18n.so: undefined reference to typeinfo for icu_70::Calendar' | ......arm-oe-linux-gnueabi/11.3.0/ld: ../../lib/libicui18n.so: undefined reference to
icu_70::CalendarAstronomer::WINTER_SOLSTICE()’
| …arm-oe-linux-gnueabi/11.3.0/ld: …/…/lib/libicui18n.so: undefined reference to icu_70::Calendar::validateField(UCalendarDateFields, UErrorCode&)' | ......arm-oe-linux-gnueabi/11.3.0/ld: ../../lib/libicui18n.so: undefined reference to
icu_70::CaseMapTransliterator::~CaseMapTransliterator()’
| …arm-oe-linux-gnueabi/11.3.0/ld: …/…/lib/libicui18n.so: undefined reference to icu_70::CalendarAstronomer::CalendarAstronomer()' | ......arm-oe-linux-gnueabi/11.3.0/ld: ../../lib/libicui18n.so: undefined reference to
utrans_rep_caseContextIterator_70’
| …arm-oe-linux-gnueabi/11.3.0/ld: …/…/lib/libicui18n.so: undefined reference to icu_70::BasicTimeZone::getTimeZoneRulesAfter(double, icu_70::InitialTimeZoneRule*&, icu_70::UVector*&, UErrorCode&) const' | ......arm-oe-linux-gnueabi/11.3.0/ld: ../../lib/libicui18n.so: undefined reference to
icu_70::getTimeZone() const’
| …arm-oe-linux-gnueabi/11.3.0/ld: …/…/lib/libicui18n.so: undefined reference to icu_70::Calendar::setTimeZone(icu_70::TimeZone const&)' | ......arm-oe-linux-gnueabi/11.3.0/ld: ../../lib/libicui18n.so: undefined reference to
icu_70::CalendarAstronomer::getMoonAge()’
| …arm-oe-linux-gnueabi/11.3.0/ld: …/…/lib/libicui18n.so: undefined reference to icu_70::Calendar::getSkippedWallTimeOption() const' | ......arm-oe-linux-gnueabi/11.3.0/ld: ../../lib/libicui18n.so: undefined reference to
icu_70::CaseMapTransliterator::CaseMapTransliterator(icu_70::UnicodeString const&, int ()(int, int ()(void*, signed char), void*, char16_t const**, int))’
| …arm-oe-linux-gnueabi/11.3.0/ld: …/…/lib/libicui18n.so: undefined reference to icu_70::CalendarAstronomer::NEW_MOON()' | ......arm-oe-linux-gnueabi/11.3.0/ld: ../../lib/libicui18n.so: undefined reference to
icu_70::CalendarAstronomer::getSunTime(double, signed char)’
| …arm-oe-linux-gnueabi/11.3.0/ld: …/…/lib/libicui18n.so: undefined reference to icu_70::Calendar::getFirstDayOfWeek() const' | ......arm-oe-linux-gnueabi/11.3.0/ld: ../../lib/libicui18n.so: undefined reference to
icu_70::CalendarAstronomer::PI’
| …arm-oe-linux-gnueabi/11.3.0/ld: …/…/lib/libicui18n.so: undefined reference to icu_70::Calendar::operator=(icu_70::Calendar const&)' | ......arm-oe-linux-gnueabi/11.3.0/ld: ../../lib/libicui18n.so: undefined reference to
icu_70::getNow()’
| …arm-oe-linux-gnueabi/11.3.0/ld: …/…/lib/libicui18n.so: undefined reference to icu_70::Calendar::getLimit(UCalendarDateFields, icu_70::Calendar::ELimitType) const' | ......arm-oe-linux-gnueabi/11.3.0/ld: ../../lib/libicui18n.so: undefined reference to
icu_70::createInstance(icu_70::TimeZone*, icu_70::Locale const&, UErrorCode&)’
| …arm-oe-linux-gnueabi/11.3.0/ld: …/…/lib/libicui18n.so: undefined reference to icu_70::BasicTimeZone::BasicTimeZone(icu_70::BasicTimeZone const&)' | ......arm-oe-linux-gnueabi/11.3.0/ld: ../../lib/libicui18n.so: undefined reference to
icu_70::isSet(UCalendarDateFields) const’
| …arm-oe-linux-gnueabi/11.3.0/ld: …/…/lib/libicui18n.so: undefined reference to icu_70::Calendar::getDefaultDayInMonth(int, int)' | ......arm-oe-linux-gnueabi/11.3.0/ld: ../../lib/libicui18n.so: undefined reference to
icu_70::CalendarAstronomer::~CalendarAstronomer()’
| …arm-oe-linux-gnueabi/11.3.0/ld: …/…/lib/libicui18n.so: undefined reference to icu_70::Calendar::getDayOfWeekType(UCalendarDaysOfWeek, UErrorCode&) const' | ......arm-oe-linux-gnueabi/11.3.0/ld: ../../lib/libicui18n.so: undefined reference to
icu_70::Calendar(icu_70::TimeZone*, icu_70::Locale const&, UErrorCode&)’
| …arm-oe-linux-gnueabi/11.3.0/ld: …/…/lib/libicui18n.so: undefined reference to icu_70::Calendar::getLeastMaximum(icu_70::Calendar::EDateFields) const' | ......arm-oe-linux-gnueabi/11.3.0/ld: ../../lib/libicui18n.so: undefined reference to
icu_70::CalendarCache::get(icu_70::CalendarCache**, int, UErrorCode&)’
| …arm-oe-linux-gnueabi/11.3.0/ld: …/…/lib/libicui18n.so: undefined reference to icu_70::Calendar::weekNumber(int, int, int)' | ......arm-oe-linux-gnueabi/11.3.0/ld: ../../lib/libicui18n.so: undefined reference to
icu_70::isEquivalentTo(icu_70::Calendar const&) const’
| …arm-oe-linux-gnueabi/11.3.0/ld: …/…/lib/libicui18n.so: undefined reference to icu_70::Calendar::getMinimum(UCalendarDateFields) const' | ......arm-oe-linux-gnueabi/11.3.0/ld: ../../lib/libicui18n.so: undefined reference to
icu_70::isWeekend() const’
| …arm-oe-linux-gnueabi/11.3.0/ld: …/…/lib/libicui18n.so: undefined reference to icu_70::CalendarCache::put(icu_70::CalendarCache**, int, int, UErrorCode&)' | ......arm-oe-linux-gnueabi/11.3.0/ld: ../../lib/libicui18n.so: undefined reference to
icu_70::getActualMinimum(UCalendarDateFields, UErrorCode&) const’
| …arm-oe-linux-gnueabi/11.3.0/ld: …/…/lib/libicui18n.so: undefined reference to icu_70::Calendar::prepareGetActual(UCalendarDateFields, signed char, UErrorCode&)' | ......arm-oe-linux-gnueabi/11.3.0/ld: ../../lib/libicui18n.so: undefined reference to
icu_70::setRepeatedWallTimeOption(UCalendarWallTimeOption)’
| …arm-oe-linux-gnueabi/11.3.0/ld: …/…/lib/libicui18n.so: undefined reference to icu_70::CalendarAstronomer::SYNODIC_MONTH' | ......arm-oe-linux-gnueabi/11.3.0/ld: ../../lib/libicui18n.so: undefined reference to
typeinfo for icu_70::BasicTimeZone’
| …arm-oe-linux-gnueabi/11.3.0/ld: …/…/lib/libicui18n.so: undefined reference to icu_70::Calendar::setLenient(signed char)' | ......arm-oe-linux-gnueabi/11.3.0/ld: ../../lib/libicui18n.so: undefined reference to
icu_70::handleGetMonthLength(int, int) const’
| …arm-oe-linux-gnueabi/11.3.0/ld: …/…/lib/libicui18n.so: undefined reference to icu_70::Calendar::getTimeInMillis(UErrorCode&) const' | ......arm-oe-linux-gnueabi/11.3.0/ld: ../../lib/libicui18n.so: undefined reference to
icu_70::getGreatestMinimum(icu_70:
| …arm-oe-linux-gnueabi/11.3.0/ld: …/…/lib/libicui18n.so: undefined reference to icu_70::Calendar::add(UCalendarDateFields, int, UErrorCode&)' | ......arm-oe-linux-gnueabi/11.3.0/ld: ../../lib/libicui18n.so: undefined reference to
icu_70::BasicTimeZone::BasicTimeZone(icu_70::UnicodeString const&)’
| …arm-oe-linux-gnueabi/11.3.0/ld: …/…/lib/libicui18n.so: undefined reference to icu_70::CaseMapTransliterator::handleTransliterate(icu_70::Replaceable&, UTransPosition&, signed char) const' | ......arm-oe-linux-gnueabi/11.3.0/ld: ../../lib/libicui18n.so: undefined reference to
icu_70::set(int, int, int, int, int, int)’
| …arm-oe-linux-gnueabi/11.3.0/ld: …/…/lib/libicui18n.so: undefined reference to icu_70::Calendar::getLocaleID(ULocDataLocaleType, UErrorCode&) const' | ......arm-oe-linux-gnueabi/11.3.0/ld: ../../lib/libicui18n.so: undefined reference to
icu_70::clear(UCalendarDateFields)’
| …arm-oe-linux-gnueabi/11.3.0/ld: …/…/lib/libicui18n.so: undefined reference to icu_70::BasicTimeZone::getSimpleRulesNear(double, icu_70::InitialTimeZoneRule*&, icu_70::AnnualTimeZoneRule*&, icu_70::AnnualTimeZoneRule*&, UErrorCode&) const' | ......arm-oe-linux-gnueabi/11.3.0/ld: ../../lib/libicui18n.so: undefined reference to
icu_70::get(UCalendarDateFields, UErrorCode&) const’
| …arm-oe-linux-gnueabi/11.3.0/ld: …/…/lib/libicui18n.so: undefined reference to icu_70::Calendar::operator==(icu_70::Calendar const&) const' | ......arm-oe-linux-gnueabi/11.3.0/ld: ../../lib/libicui18n.so: undefined reference to
icu_70::handleComputeJulianDay(UCalendarDateFields)’
| …arm-oe-linux-gnueabi/11.3.0/ld: …/…/lib/libicui18n.so: undefined reference to icu_70::BasicTimeZone::~BasicTimeZone()' | ......arm-oe-linux-gnueabi/11.3.0/ld: ../../lib/libicui18n.so: undefined reference to
icu_70::clear()’
| …arm-oe-linux-gnueabi/11.3.0/ld: …/…/lib/libicui18n.so: undefined reference to icu_70::Calendar::computeGregorianFields(int, UErrorCode&)' | ......arm-oe-linux-gnueabi/11.3.0/ld: ../../lib/libicui18n.so: undefined reference to
icu_70::setTimeInMillis(double, UErrorCode&)’
| …arm-oe-linux-gnueabi/11.3.0/ld: …/…/lib/libicui18n.so: undefined reference to icu_70::Calendar::getMaximum(icu_70::Calendar::EDateFields) const' | ......arm-oe-linux-gnueabi/11.3.0/ld: ../../lib/libicui18n.so: undefined reference to
icu_70::getRepeatedWallTimeOption() const’
| …arm-oe-linux-gnueabi/11.3.0/ld: …/…/lib/libicui18n.so: undefined reference to icu_70::Calendar::getLeastMaximum(UCalendarDateFields) const' | ......arm-oe-linux-gnueabi/11.3.0/ld: ../../lib/libicui18n.so: undefined reference to
icu_70::fieldDifference(double, icu_70:
:EDateFields, UErrorCode&)’
| …arm-oe-linux-gnueabi/11.3.0/ld: …/…/lib/libicui18n.so: undefined reference to icu_70::Calendar::getMaximum(UCalendarDateFields) const' | ......arm-oe-linux-gnueabi/11.3.0/ld: ../../lib/libicui18n.so: undefined reference to
icu_70::adoptTimeZone(icu_70::TimeZone*)’
| …arm-oe-linux-gnueabi/11.3.0/ld: …/…/lib/libicui18n.so: undefined reference to icu_70::Calendar::getDefaultMonthInYear(int)' | ......arm-oe-linux-gnueabi/11.3.0/ld: ../../lib/libicui18n.so: undefined reference to
icu_70::getActualMaximum(UCalendarDateFields, UErrorCode&) const’
| …arm-oe-linux-gnueabi/11.3.0/ld: …/…/lib/libicui18n.so: undefined reference to icu_70::Calendar::handleComputeFields(int, UErrorCode&)' | ......arm-oe-linux-gnueabi/11.3.0/ld: ../../lib/libicui18n.so: undefined reference to
icu_70::getGreatestMinimum(UCalendarDateFields) const’
| …arm-oe-linux-gnueabi/11.3.0/ld: …/…/lib/libicui18n.so: undefined reference to icu_70::Calendar::getMinimalDaysInFirstWeek() const' | ......arm-oe-linux-gnueabi/11.3.0/ld: ../../lib/libicui18n.so: undefined reference to
icu_70::~Calendar()’
| …arm-oe-linux-gnueabi/11.3.0/ld: …/…/lib/libicui18n.so: undefined reference to icu_70::Calendar::newerField(UCalendarDateFields, UCalendarDateFields) const' | ......arm-oe-linux-gnueabi/11.3.0/ld: ../../lib/libicui18n.so: undefined reference to
icu_70::BasicTimeZone::BasicTimeZone()’
| …arm-oe-linux-gnueabi/11.3.0/ld: …/…/lib/libicui18n.so: undefined reference to icu_70::Calendar::computeFields(UErrorCode&)' | ......arm-oe-linux-gnueabi/11.3.0/ld: ../../lib/libicui18n.so: undefined reference to
icu_70::computeTime(UErrorCode&)’
| …arm-oe-linux-gnueabi/11.3.0/ld: …/…/lib/libicui18n.so: undefined reference to icu_70::CalendarAstronomer::setTime(double)' | ......arm-oe-linux-gnueabi/11.3.0/ld: ../../lib/libicui18n.so: undefined reference to
icu_70::isWeekend(double, UErrorCode&) const’
| …arm-oe-linux-gnueabi/11.3.0/ld: …/…/lib/libicui18n.so: undefined reference to icu_70::CalendarAstronomer::getSunLongitude()' | ......arm-oe-linux-gnueabi/11.3.0/ld: ../../lib/libicui18n.so: undefined reference to
icu_70::roll(UCalendarDateFields, int, UErrorCode&)’
| …arm-oe-linux-gnueabi/11.3.0/ld: …/…/lib/libicui18n.so: undefined reference to icu_70::Calendar::createInstance(icu_70::Locale const&, UErrorCode&)' | ......arm-oe-linux-gnueabi/11.3.0/ld: ../../lib/libicui18n.so: undefined reference to
icu_70::set(UCalendarDateFields, int)’
| …arm-oe-linux-gnueabi/11.3.0/ld: …/…/lib/libicui18n.so: undefined reference to icu_70::CaseMapTransliterator::CaseMapTransliterator(icu_70::CaseMapTransliterator const&)' | ......arm-oe-linux-gnueabi/11.3.0/ld: ../../lib/libicui18n.so: undefined reference to
icu_70::complete(UErrorCode&)’
| …arm-oe-linux-gnueabi/11.3.0/ld: …/…/lib/libicui18n.so: undefined reference to icu_70::Calendar::getWeekendTransition(UCalendarDaysOfWeek, UErrorCode&) const' | ......arm-oe-linux-gnueabi/11.3.0/ld: ../../lib/libicui18n.so: undefined reference to
icu_70::setRelatedYear(int)’
| …arm-oe-linux-gnueabi/11.3.0/ld: …/…/lib/libicui18n.so: undefined reference to icu_70::Calendar::handleGetExtendedYearFromWeekFields(int, int)' | ......arm-oe-linux-gnueabi/11.3.0/ld: ../../lib/libicui18n.so: undefined reference to
icu_70::BasicTimeZone::hasEquivalentTransitions(icu_70::BasicTimeZone const&, double, double, signed char, UErrorCode&) const’
| …arm-oe-linux-gnueabi/11.3.0/ld: …/…/lib/libicui18n.so: undefined reference to icu_70::Calendar::Calendar(icu_70::TimeZone const&, icu_70::Locale const&, UErrorCode&)' | ......arm-oe-linux-gnueabi/11.3.0/ld: ../../lib/libicui18n.so: undefined reference to
icu_70::getRelatedYear(UErrorCode&) const’
| …arm-oe-linux-gnueabi/11.3.0/ld: …/…/lib/libicui18n.so: undefined reference to typeinfo for icu_70::CaseMapTransliterator' | ......arm-oe-linux-gnueabi/11.3.0/ld: ../../lib/libicui18n.so: undefined reference to
icu_70::roll(icu_70:
:EDateFields, int, UErrorCode&)’
| collect2: error: ld returned 1 exit status
| make[2]: *** [Makefile:81: …/…/bin/makeconv] Error 1
| make[2]: Leaving directory ‘/build/tmp/raspberrypi3-glibc/work/cortexa7t2hf-neon-vfpv4-oe-linux-gnueabi/icu/70.1-r0/build/tools/makeconv’
| make[1]: *** [Makefile:47: all-recursive] Error 2
| make[1]: Leaving directory ‘/build/tmp/raspberrypi3-glibc/work/cortexa7t2hf-neon-vfpv4-oe-linux-gnueabi/icu/70.1-r0/build/tools’
| make: *** [Makefile:153: all-recursive] Error 2
| ERROR: oe_runmake failed
| WARNING: exit code 1 from a shell command.
ERROR: Task (/chirpstack-gateway-os/layers/openembedded/openembedded-core/meta/recipes-support/icu/icu_70.1.bb:do_compile) failed with exit code ‘1’
NOTE: Tasks Summary: Attempted 1569 tasks of which 1561 didn’t need to be rerun and 1 failed.
Summary: 1 task failed:
/chirpstack-gateway-os/layers/openembedded/openembedded-core/metarecipes-support/icu/icu_70.1.bb:do_compile
Summary: There were 2 ERROR messages, returning a non-zero exit code.
