Thank you for your reply. Actually, I am not familiar with docker. It would be helpful if you can suggest any alternative ways. Otherwise, Kindly suggest me a documentation/link to install the chirpstack server or similar server in my system using docker.
Dear @bconway,
As you said I tried building from source using docker-compose. I followed the following steps:
step 1: Download the chirpstack network server, application server and gateway bridge zip files from github. step 2: Unzip them in Home directory step 3: Get inside the chirpstack-gateway-bridge-master directory and run the command docker-compose run --rm chirpstack-gateway-bridge bash step 4: Get inside the chirpstack-network-server-master directory and run the command docker-compose run --rm chirpstack-network-server bash step 5: Get inside the chirpstack-application-server directory and run the command docker-compose run --rm chirpstack-application-server bash
Following containers are running on my system:
I am unable to access the chirpstack-application-server web interface. Did I complete all of the processes correctly, or do some more steps need to be completed? kindly help.
