Can a gateway report to more than one network-server?
I wonder if a gateway can report to 2 different network server.
My use case is :
  • i have a remote network server/app server to which several gateways report my device data
  • i have a “mobile” gateway, inside a car, with no permanent network connection. I would like this “mobile” gateway to report to a local server (meaning in same LAN) in order to locally see if frames are received AND to report to my remote network/app servers
Maybe the solution stated here is not the best way to achieve this goal btw !
Thx by advance,
S.
Yes, it can :slight_smile: In case of MQTT, there could be multiple subscribers, or you could forward data from one MQTT broker to an other.
An other option is https://github.com/brocaar/chirpstack-packet-multiplexer to forward UDP data to multiple NS instances.
