I’m running ChirpStack on Debian and currently using chirpstack-gateway-bridge with the semtech_udp backend (port 1700) for my gateways.
Now I would like to also support Basic Station gateways (using the basic_station backend on port 3001 with TLS).
I understand that only one backend can be defined in chirpstack-gateway-bridge.toml, but I’d like to confirm:
1. Is it possible to run two separate instances of chirpstack-gateway-bridge on the same machine, each with its own config file – one for semtech_udp, the other for basic_station?
For example:
/etc/chirpstack-gateway-bridge/chirpstack-gateway-bridge.toml→ for UDP/etc/chirpstack-gateway-bridge/chirpstack-gateway-bridge-basicstation.toml→ for Basic Station
And launch both using separate systemd units?
- Alternatively – is there any supported way to define both backends in a single
chirpstack-gateway-bridge.tomlfile (like amultimode)?
If yes – could someone share a working example?
Thanks in advance for your help!
