Do we have provision to use a different MQTT topic for loraWAN other than template:
uplink_topic_template=“application/{{ .ApplicationID }}/device/{{ .DevEUI }}/rx”
downlink_topic_template=“application/{{ .ApplicationID }}/device/{{ .DevEUI }}/tx”
if so where should we change?
I believe you are already looking at the configuration values
When you update these and restart lora-app-server
, it will use the updated names for publishing data.
Can i have provision to use a different topic like A/rx(for uplink) and A/tx(downlink) (eg: 0001010101000001/rx )…Where A- 16 byte unique id represents device
If possible, where should we provide applicationID and deveui (as we are not giving in topic of mqtt)…?
if I change the uplink_topic_template and downlink_topic_template in both loraserver.toml file and lora-gateway-bridge.toml file to format A/rx and A/tx , will it works??
This is not possible:
# Note: the downlink_topic_template must contain both the application id and
# DevEUI substitution!
That is, the templates must mention {{ .ApplicationID }}
and {{ .DevEUI }}
, while the rest is up to you.
