Logs from app server pod log:
time=“2021-04-05T17:40:54Z” level=fatal msg=“setup storage error: storage: applying PostgreSQL data migrations error: pq: invalid byte sequence for encoding “UTF8”: 0x00 handling 0046_devaddr_appskey_to_device.sql”
I tried few versions of pgsql and app server from latest to 3.10 and got same error every time.
I follow yamls from here:
and here:
with same result please can you advise what should i change.
Thank you.
We moved the repository to: https://gitlab.com/wobcom/iot/chirpstack-helm
But that should not be your issue, did you try a fresh DB every time you tested a new version?
You still need to provide a database properly configured:
AS:
-- create the chirpstack_as user
create role chirpstack_as with login password 'dbpassword';
-- create the chirpstack_as database
create database chirpstack_as with owner chirpstack_as;
-- enable the trigram and hstore extensions
\c chirpstack_as
create extension pg_trgm;
create extension hstore;
-- exit the prompt
\q
If using Zalando’s Postgresql Operator:
apiVersion: "acid.zalan.do/v1"
kind: postgresql
metadata:
namespace: chirpstack
spec:
teamId: "chirpstack"
volume:
numberOfInstances: 1
preparedDatabases:
chirpas:
defaultUsers: true
extensions:
pg_trgm: public
hstore: public
postgresql:
version: "12"
NS:
-- create the chirpstack_ns user with password 'dbpassword'
create role chirpstack_ns with login password 'dbpassword';
-- create the chirpstack_ns database
create database chirpstack_ns with owner chirpstack_ns;
-- exit the prompt
\q
kind: postgresql
metadata:
spec:
volume:
preparedDatabases:
chirpns:
defaultUsers: true
postgresql:
version: "12"
